505 error
Moderators: cnckeith, Joey
repauli1
505 error
Post by repauli1 »
Anyone else getting a 505 error "invalid value" error after loading a (newest version sheetcam, AND Centroid Acorn 8.2) a gcode file, and pressing GRAPH?
Will upload report when customer is available.
Bob
Joey
Plasma/Laser Lead
Re: 505 error
Post by Joey »
Haven't update the latest version of Sheetcam. Will check that out here shortly
Joey
Plasma/Laser Lead
Re: 505 error
Post by Joey »
Just threw a couple dxf's into the latest SheetCam TNG V7.0.20. Everything worked as expected. Can you throw the Gcode file up so I can have a look at it.
fisher_transport
CNC Control System Serial Number: 3484e425f500-0513226202
Re: 505 error
Post by fisher_transport »
joey you want to team view my system and check it out? i tried uploading file but the forum system wont except .tap or .job
fisher_transport
Re: 505 error
file
dex.txt
(71.68 KiB) Downloaded 12 times
Joey
Plasma/Laser Lead
Re: 505 error
Post by Joey »
I'd like to check it out yes. I just tried the file on my machine and I'm able to run it.
Joey
Plasma/Laser Lead
Re: 505 error
Post by Joey »
Send me an email or txt a picture of the Team Viewer info. You can call my cell when your ready. Email mccullochjoey@gmail.com
Cell: 8145711043
Joey
Plasma/Laser Lead
Re: 505 error
Post by Joey »
Have tried loading the .TXT file you posted? That's what I loaded. But I'm not sure the gcode is exactly right...
fisher_transport
Re: 505 error
joey didnt want to txt you but this look better?
Joey
Plasma/Laser Lead
Re: 505 error
Post by Joey »
Results were the gcode that Sheetcam was outputting had M codes from another system that could not be read. In the gcode file that was posted the lines that started with M67 were commented out because they were causing CNC12 to throw an error. M67 is not used or read by CNC12 and cannot be used.
Lesson from this is it's a good idea to remove any previous systems mcodes or setting when using Sheetcam for Acorn Plasma. Once the previous systems settings were removed Sheetcam posted clean Gcode that functioned properly with Acorn Plasma.
