Post
by suntravel »
I needed a function to mill an circle or an ellipse only with a few lines G-code.
So I made an interpolation with a simple GOTO loop
Another cool thing is that it works with G51 scaling (G2/3 can not be scaled to be an ellipse)
G40 G21
G94 G80
G54
M6 T8
G43 D8
M3 S3000
T8 M6
G43 Z2 H8
G51 X0.0 Y0.0 Z0.0 I1 J1 K1 ; Scaling ON
#120 = 1 ; Incremental degree calculation
#121 = 0 ; Start Angle
#122 = 15 ; Y Axis Radius
#123 = 30 ; X Axis Radius
#130 = #4122 ; Current Diameter from tool offset
X[#123+2+#130] Y0 ; Rapid to Start point
G1 Z-4 F300 ; Dive to depth
G42 X#123 D8 ; Compensation motion to ellipse
N10 #121 = [#121 + #120] ; Angular Count
#124 = SIN[#121] ; Incremental Y axis calculation
#125 = COS[#121] ; Incremental X axis calculation
#124 = [#124*#122] ; Absolute Y calculation
#125 = [#125*#123] ; Absolute X calculation
X#125 Y#124 ; Movement in X & Y axis
IF [#121 < 360] GOTO 10 ; Restart if less than 360 degree motion
IF [#121 > 360] GOTO 20 ; If final angle becomes greater than 360 degrees recalculate
IF [#121 == 360] GOTO 30 ; Finish if total angle is equal to 360 degree
N20 #121 = 360
GOTO 10
N30 G40 X[#123+2+#130]
G50 ; Scaling OFF
G0 G90 Z5 M30
S0
M5
M30
![ellipse.jpg (112.88 KiB) Viewed 770 times ellipse.jpg](./download/file.php?id=22063&t=1&sid=bea32f4f1ee85b1f807e84a8d510a7eb)
Post
by suntravel »
Added function to rotate the ellipse and to set start and end angle, define center in X and Y
Now it is possible to integrate the function in other tool paths...
G40 G21
G94 G80
G54
M6 T8
G43 D8
M3 S3000
T8 M6
G43 Z2 H8
#121 = 45 ; Start Angle
#134 = 180 ; End Angle
#131 = 20 ; X position of center
#132 = 10 ; y position of center
#133 = 45 ; R45otation Angle
G68 R[#133] X[#131] Y[#132] ; Rotation
#124 = [[#124*#122]+#132] ; Absolute Y calculation
#125 = [[#125*#123]+#131] ; Absolute X calculation
X[#125] Y[#124] ; Rapid to Start point
G42 X[#125] Y[#124] D8 ; Compensation motion to ellipse
IF [#121 < #134] GOTO 10 ; Restart if less than 360 degree motion
IF [#121 > #134] GOTO 20 ; If final angle becomes greater than 360 degrees recalculate
IF [#121 == #134] GOTO 30 ; Finish if total angle is equal to 360 degree
N20 #121 = #134
GOTO 10
N30
Z2
G40
G50 ; Scaling OFF
G69 ; Rotation OFF
G0 G90 Z5 M30
S0
M5
M30
![Ellipse.jpg (65.96 KiB) Viewed 760 times Ellipse.jpg](./download/file.php?id=22066&t=1&sid=bea32f4f1ee85b1f807e84a8d510a7eb)
