Clearpath issues On new gantry
Posted: Thu Oct 20, 2022 6:00 pm
by AtomicAsian
I finally built a new gantry with dual servos.
Tunning and test cutting has improved. NOW I'm wanting the perfect circle and overall cuts
I'm getting a jitter after lead in. circles are not great.
My table is very jerky after each cut moving to the next cut.
What can I do to smooth out this table?
report below
Re: Clearpath issues On new gantry
Posted: Thu Oct 20, 2022 8:23 pm
share screen shots of the Clearpath software setups for each motor.
Posted: Thu Oct 20, 2022 8:24 pm
do you have a gear box between the axis motor and the pinion? if so what is the reduction ratio?
Posted: Fri Oct 21, 2022 8:40 pm
by AtomicAsian
I’ll get some shots tomorrow.
Yes 5:1 gearbox 24t pinion
Posted: Sat Oct 22, 2022 7:23 pm
by jcoldon
you posted this on my FB page . your reduction needs to be 10 to 1 for 1.75 pinion your motor selection small for heavy gantry using large linear slides . your motor only 240 oz inch combined with 5 to 1 drive and 1.75 inch pinion Gona take lot power to move at 350 ipm cut speeds with high acceleration . try 10 to 1 reduction planetary drive go from there . it might just work with small servo . better servo choice be 750 ac servo that others used on that table build what size are the linear rails they look like 25 or 30 mm in pic . slides that size have resistance that motor has to over come . plasma needs high acceleration no velocity slow down to do good Hypertherm book speeds
Posted: Sat Oct 22, 2022 7:34 pm
by jcoldon
Another question looking at that gantry seeing how high it is built out thin welded steel . with the power on and you push on rises left to right does the gantry move . any movement will show in cuts. i don't do risers that high they shake with high acceleration of plasma . Another with motor not engaged in the gear pushing the y axis on one side any resistance or binding 1 finger pinky push any more needed it binding this goes for y and x axis. linear slides not bolted to dead on flat plate 2 of them will bind cause cut problems they need like 2 k accuracy not to bind mainly machined flat surface .
Posted: Wed Nov 02, 2022 1:01 pm
by AtomicAsian
Shit thankyou.
Posted: Wed Nov 02, 2022 1:10 pm
by AtomicAsian
originally the Y has a single servo with a 10:1 and a 2 3/8 spur
Everyone recommended the 5:1. clearpath even did with the smaller spur. i did change the gantry to aluminum square tube to lighten it up. Teknic support had to tune the X axis from their end manually. it helped a lot. but i still get a small jitter when cornering. also the thicker mater 3/16” the cuts are sputtering but consistent and cuts all the way through. My first table i built in my garage with chinese ebay parts cuts way better than this table.
Posted: Mon Nov 07, 2022 11:59 am
by jcoldon
You been posting cuts on hear and my FB page cnc plasma table builders .
If you are running a 2 inch spur gear with 5 to 1 reduction your results not Gona be good . your resolution not Gona be good nor is your acceleration
That why the table had 10 to 1 in it original designee you got bad advice using 5 to 1 with 2 inch gear and your small motor selection
Plasma about acceleration and constant velocity .
how good it your gear contact . i don't see any float setup . with out a float your rack and linear rail need to be dead on . using float for constant gear pressure better it keep constant force on gear .. just sitting there you push on gantry does anything move any movement over 3 k inch will show in cuts
i see your gantry is very high. torch extended all the way down that cause some movement also
do a test cut some heavy steel like 1/2 inch then cut some thinner gauge i bet the thick steel smoother then the thin stuff
that be sure indicator motion is not good also turn off acorn smoothing in profile mgr
Hypertherm has book speeds if you cant do the book speeds then you'll have to fudge your settings
i been building plasma tables over 20 years i been threw a lot of failed designs that why i always say keep it simple in designed
everything needed for Propper drive selection on my FB page in file section is a DMM servo XL spred sheet it work on any servo to give you an idea on gantry size and weight . your cuts got better once you removed heavy gantry beam . that shows right there you need mor power of higher gear box 10 to 1 using 2 inch pinion i realize that designee wont let you use a 1 inch pinion motor hit the riser . tables running larg e 2 inch gears running 750 watt or more ac servo .
What are your acceleration settings and max ipm settings set at i usually do max then back off 30 percent for safety
my acceleration settings are .15 with 900 ipm any faster i rip a gear off theirs no slow down in circles and curves
