Wireless pendant problem <solve com errors, see thread>
Well it works all fine, but occasionally when im jogging or using lathe as manual lathe with pendant it will get stuck going only one direction. Meaning only in positve or a neg direction and when this happens it also changes the increment speed slower too. Ill post a video showing it. And later ill upload the file. Not near machine atm.
- report_F045DA7F3FF3-1107181307_2022-10-03_14-25-23.zip
- (719.94 KiB) Downloaded 2 times
Re: Wireless pendant problem
stuck in one direction at slow speed is what happens when you unexpectedly trip the probe, or i think limit switch
check that?
check that?
post a fresh report.zip so we can see your settings error message history.
added to first post
i think this is my error log.
- msg_log.txt
- (381.9 KiB) Downloaded 2 times
video date was oct 3rd 2022 at 2.25pm
here is your problem.
(4) 10-03-2022 14:21:13 944 MPU requested resend # 67
(4) 10-03-2022 14:21:13 946 PC resending # 671
(4) 10-03-2022 14:21:15 944 MPU requested resend # 68
(4) 10-03-2022 14:21:15 946 PC resending # 674
(4) 10-03-2022 14:21:34 944 MPU requested resend # 69
(4) 10-03-2022 14:21:34 946 PC resending # 677
(4) 10-03-2022 14:21:36 944 MPU requested resend # 70
(4) 10-03-2022 14:21:36 946 PC resending # 680
(4) 10-03-2022 14:21:44 944 MPU requested resend # 71
(4) 10-03-2022 14:21:44 946 PC resending # 683
(4) 10-03-2022 14:21:45 944 MPU requested resend # 72
(4) 10-03-2022 14:21:45 946 PC resending # 713
(4) 10-03-2022 14:21:46 944 MPU requested resend # 73
(4) 10-03-2022 14:21:46 946 PC resending # 716
(4) 10-03-2022 14:21:47 944 MPU requested resend # 74
(4) 10-03-2022 14:21:47 946 PC resending # 719
(4) 10-03-2022 14:21:48 944 MPU requested resend # 75
(4) 10-03-2022 14:21:48 946 PC resending # 722
(4) 10-03-2022 14:21:54 944 MPU requested resend # 76
(4) 10-03-2022 14:21:55 946 PC resending # 725
(4) 10-03-2022 14:22:07 944 MPU requested resend # 77
(4) 10-03-2022 14:22:07 946 PC resending # 728
(4) 10-03-2022 14:22:22 944 MPU requested resend # 78
(4) 10-03-2022 14:22:22 946 PC resending # 730
(4) 10-03-2022 14:22:56 944 MPU requested resend # 79
(4) 10-03-2022 14:22:56 946 PC resending # 732
(1) 10-03-2022 14:22:58 OVERRIDE IS DISABLED FOR RAPID MOVES
(1) 10-03-2022 14:23:00 OVERRIDE IS ENABLED FOR RAPID MOVES
(4) 10-03-2022 14:25:03 944 MPU requested resend # 80
(4) 10-03-2022 14:25:04 946 PC resending # 735
(1) 10-03-2022 14:25:23 Creating report...
thanks for posting the report.
Update to v4.80 which has advanced communication debug tool
and follow the guidance here.
https://centroidcncforum.com/viewtopic.php?f=61&t=1451
Re: Wireless pendant problem <solve com errors, see thread>
Will do and if it happens again do i repost it here or make a new thread?
keep a thread going if it is the same subject, thanks.
