How to setup and use Gang Tooling with Acorn Lathe
Posted: Fri Jun 10, 2022 11:42 pm
by suntravel
I have written a small guide about Gang Tooling with Acorn
Hope this is easy to follow for people new with Acorn.
If something is missing pls. let me know.
A Video about Gang Tolling will follow the next days.
Edit
I replaced the PDF with a better version.
Re: How to setup and use Gang Tooling with Acorn Lathe
Posted: Sat Jun 11, 2022 10:08 pm
by knastenrad
this is great.
thank you
looking forward to the video :)
Posted: Sun Jun 12, 2022 9:58 am
by suntravel
Video:
Added a few lines to the program to use the Cut Off tool as a stop to make a series of bolts fast.
Posted: Tue Jun 14, 2022 12:28 am
by BillB
Uwe, This is very helpful, Thank you for putting this together. I was wondering of you have info on the tool touch off you purchased and set up for your lathe. And if you have time to add that to this guide that would be really great I would like to add one for mine.
Posted: Tue Jun 14, 2022 6:53 am
by suntravel
BillB wrote: Tue Jun 14, 2022 12:28 am Uwe, This is very helpful, Thank you for putting this together. I was wondering of you have info on the tool touch off you purchased and set up for your lathe. And if you have time to add that to this guide that would be really great I would like to add one for mine.
This is all here:
https://centroidcncforum.com/viewtopic.php?f=60&t=6963
Posted: Mon Apr 24, 2023 2:32 pm
by slodat
Uwe - How do you do the block 2 and 3 in the video? This is where you are positioning the cutoff tool and a M200 to pull the bar out to the cutoff tool? How do you do this in Intercon?
Posted: Tue Apr 25, 2023 7:02 am
by suntravel
slodat wrote: Mon Apr 24, 2023 2:32 pm Uwe - How do you do the block 2 and 3 in the video? This is where you are positioning the cutoff tool and a M200 to pull the bar out to the cutoff tool? How do you do this in Intercon?
You can write g-code lines in intercon, but I do this with Npp...
Posted: Tue Apr 25, 2023 9:51 am
by slodat
Npp?
Posted: Tue Apr 25, 2023 9:54 am
by suntravel
Notepad ++
