The video on the Acorn Plasma
Posted: Tue May 03, 2022 11:07 pm
by lilb93
Watched the video yesterday on the acorn Plasma. Was really good. Just got in a Langmuir XR 4X8 table. Wondering how easy it would be to change it over to Acorn.
Re: The video on the Acorn Plasma
Posted: Wed May 04, 2022 2:11 pm
lilb93 wrote: Tue May 03, 2022 11:07 pm Watched the video yesterday on the acorn Plasma. Was really good. Just got in a Langmuir XR 4X8 table. Wondering how easy it would be to change it over to Acorn.
Its doable.
Currently only Hypertherm Powermax plasma cutters are supported if you want to use torch height control.
If you don't you don't have to use it. In the future if you get a Hypertherm Powermax, then you could add the THC.
It would be up to you to add a breakaway and an OHMIC sensing tip or floating switch on the Z axis
Posted: Tue May 10, 2022 10:49 pm
by lilb93
Got the Langmuir XR in opened the control box looks to be a real easy changeover. Why only Hypertherm does the board know your using joe smuch plasma?
Posted: Tue May 10, 2022 11:26 pm
It is the cleanliness of the torch voltage.
Hypetherm only to use the Centroid THC
Posted: Thu May 12, 2022 3:44 pm
martyscncgarage wrote: Tue May 10, 2022 11:26 pm It is the cleanliness of the torch voltage.
we support Lincoln Flex Cut as well.
and trying to work with Thermal Dynamics unit now to add to the list.
