Connection Problems
CNCisRobot
Connection Problems
Post by CNCisRobot »
Hi,
I need some help desperately I have an old GRBL system that I am looking to replace, and I already have a BBG and BBB board as I am into electronics. I want to run the ACORN software and see if I like it, as there is no demo mode, my plan is to make the BBG connect to my original break out board hardware. But I have tried 2 computers 4 network cards 6 cables, and tried with a switch and I always get an error in the communications and the software then closes. The BBG has a heartbeat led flash, but I am suspecting it could be because it is not connected to the ACORN breakout board, and it needs to see this to continue. I cant find a circuit diagram of the ACORN breakout board so no clues there. If someone knows the answer or could possibly do me a big favour and do a test for me by unplugging your BBG board from the breakout board power it up by the micro USB and see if you can connect with the ethernet to see if the software will open and stay running and not close down. This will help me to know what is happening. I would just buy the kit but I don’t have money as I have lost my job recently and money is tight.
Thank you
Darren.
Gary Campbell
Re: Connection Problems
Post by Gary Campbell »
In order to connect to the CNC12 software on the PC you are going to have to have a properly flashed BBG AND have it connected to an Acorn BOB. The ID chips that enable connection are on the Acorn board itself.
PS: You're going to like it :D
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
What is your machine like? 3 steppers, or 4 steppers ?
You can download the servo version of CNC12 that does have a demo mode. There is no VCP or Wizard, but the interface and functionality is the same.
CNCisRobot
So the answer is there is a chip on the breakout board, which connects to the BBG which will then allow the connection and the software to run. So without schematics of the breakout board I cant add the chip to my breakout board setup. So my next problem is where I can just buy the Acorn break out board as I already have everything else. Also I am in the UK.
CNCisRobot
Can I buy just the breakout board then as I have everything else, thank you.
CNCisRobot wrote: Fri Mar 04, 2022 2:29 pm Can I buy just the breakout board then as I have everything else, thank you.
Hello. Sorry the Acorn CNC controller is sold as a kit.
