Question about affects of Offset Screen
Posted: Thu Feb 04, 2021 8:20 pm
by terrymcc
I am having the following issue;
If I am at the home screen and have selected a tool, the reading would be T02 H02 for example with tool 2 having been selected.
If I open (and don't even change anything) in the tool offset screen and return to the main screen, it reads T02 H---
If I go to MDI and request T02H02, it remains T02 H---. I have to go in and reset the Part Z0 to get the display back. this can be pretty painful depending on what is set up...
If I go ahead and run a program, its OK but I can't use MDI.
Am I doing something wrong or is this the intended operation?
Re: Question about affects of Offset Screen
Posted: Thu Feb 04, 2021 9:30 pm
by DrLocke
G43 T2 H2 M06
Posted: Fri Feb 05, 2021 1:56 pm
set parameter #3 = 4
users manual.
and upgrade to v4.62 free support for v4.5 has ended.:-))
Posted: Fri Feb 05, 2021 5:32 pm
by terrymcc
I do... I've just spent so long getting everything up and going on both lathe and mill, I'm anxious about possibly loosing it. Need to look up the doc on doing a software upgrade.
Posted: Sat Feb 06, 2021 3:39 pm
just make a copy of your existing cncm or cnct directory, if you want to go back to the old stuff simple rename/copy it back. easy peasy.
Posted: Tue Feb 09, 2021 7:44 am
by cbb1962
cnckeith wrote: Fri Feb 05, 2021 1:56 pm set parameter #3 = 4
So I'm checking to make sure I understand how bit-mapped values work:
If I want the Reference tool position set to Z home AND Tool Height Retention Option ON
then I would set parameter #3 = 6
Is this correct?
Posted: Tue Feb 09, 2021 2:41 pm
by cncsnw
That is correct.
