New Install - No Wizard <resolved>
I have just installed CNC 12 Mill on a desktop that meets requirements and has been setup per the video. Everything everything went as it showed on the install/benchtest video except the wizard did not launch and cannot be found on the desktop or anywhere else. I then rebooted and still no wizard. I then shut down, disconnected the Acorn, rebooted, uninstalled, connected Acorn, rebooted, and reinstalled. For the second install, I downloaded again on another PC, unzipped and saved to thumb drive to put on the CNC PC. Still has the same issue. The CNC PC has no internet until I receive my wireless adapter. Could this be the issue?
Re: New Install - No Wizard
Are you using a widescreen monitor?
Yes. it's a Dell and it's 1920x1200.
Go to the bottom of the screen and look for the utility button. After you click it you will see the Wizard option.
Yes! It worked! Thank you! I remember Franko mentioning that the wizard was now inside the program but I couldn’t find it and the not matching the video is what threw me off. Thanks again!
