Hybrid Step-Servo input
ARTMEK
CNC Control System Serial Number: 5JP98711918879705-985DADEB78D8-0110180511
Post by ARTMEK »
Hi, I want to use the screw terminals for my closed loop steppers and make sure I don't let out any smoke first thing.
So I'm guessing:
COM to PUL-/DIR-
and
STEP/DIR to PUL+/DIR+ with 2k resistors in serie?
Best
Gary Campbell
Re: Hybrid Step-Servo input
Post by Gary Campbell »
If you wish to have questions answered about the drive connections, please attach a pdf of copy of the drives manual
cbb1962
Post by cbb1962 »
Clint in NW Arkansas
ARTMEK wrote: Thu Mar 28, 2019 5:39 am Hi, I want to use the screw terminals for my closed loop steppers and make sure I don't let out any smoke first thing.
So I'm guessing:
COM to PUL-/DIR-
and
Best
Like Gary said, provide a link to your drive manual.
Initially, without seeing the manual I would say no to the way you are proposing to do it.
WHY do you want to use the header instead of the DB25 with a breakout board. It was designed for the type of drive you want to use.
More information provided by you will get you some more help.
Gary Campbell
I took a quick peek at the specs online. Those are inexpensive Chinese clones of LeadShine products. You need to connect to the DB25 header, NOT the screw terminals.
ARTMEK
Post by ARTMEK »
Thanks for replying so fast!
So here is the full PDF:
Manual 2HSS57.pdf
(432.56 KiB) Downloaded 111 times
The first picture I posted propose 5V, 12V or 24V signal if using resistor. Still don't understand why i must use the DB25.
Best
ARTMEK wrote: Thu Mar 28, 2019 1:26 pm Thanks for replying so fast!
Manual 2HSS57.pdf
Best
Because the proper logic signals for your drive are on the DB25.
If you want to try the Acorn header terminals, take +5VDC from the Acorn power supply and take it to
+Puls
+Dir
Take -Puls to Acorn Header Terminal ST
Take -Dir to Acorn Header Terminal DR
Try that for starters
ARTMEK
Post by ARTMEK »
Worked great like above!
