Axis config won't save?
Posted: Sun Aug 17, 2025 11:01 am
by justcrankinit
I'm not sure what I am missing, but I can't seem to get my previously working axis configuration to load and save. Each time I close Acorn and reboot the wizard reverts to the Kl-5060E standard configuration.
I do have Automation Technology drives but they are Kl-8060E, and everything worked as it should before the update.
Re: Axis config won't save?
Posted: Mon Aug 18, 2025 9:51 am
by ShawnM
Silly question but after you select the drive to load you are clicking the large green button in the lower right corner and following the on screen prompts to save that configuration, yes?
Secondly, you can create a "custom" drive configuration for your particular drive model number and save that configuration if you like.
Posted: Mon Aug 18, 2025 3:52 pm
click "load drive" then click "write settings to cnc control"
