File Size Issue Lathe Pro version 4.08 - Resolved
Posted: Sun Nov 26, 2017 2:41 pm
by frijoli
I loaded a 6kb file and Acorn lathe pro is telling me I need to upgrade because the file is over 4mg.
It may be something in the post process but I can't imagine where.
Report attached if it's useful.
EDIT: I cannot even run the sample files that are over 5kb, provided by Centroid. These are the samples that come on the zip file for the software download.
diycncscott wrote:
I was able to re-create your issue. I have emailed you a new license to: cferriola@tri__.__.com
If you need it sent to a different email address, please send me an email at support@centroidcnc.com
file size issue
Posted: Sun Nov 26, 2017 9:51 pm
by frijoli
I have run into a few hurdles.
1. The program size is a bug. This is the sample program from Centroid and it is 7kb. I have pro software running, but every file over 5kb fails to load.
2. The program error message 417 does nothing to help troubleshoot the gcode.. lol
Re: File size incorrect? (edited:BUG)
Posted: Mon Nov 27, 2017 10:27 am
by diycncscott
Hello,
Please try re-importing the license.dat file from scratch as shown below.
1. Please delete c:\cnct\license.dat
2. Download the attached file:
3. Rename the downloaded file to: license-scott-985DAD4295AE-1005170145-pro-lathe.dat (remove the .txt from the end of the name)
4. Go back into F7-Utility->F8-Options->F2-Import License and select the file downloaded above.
Posted: Mon Nov 27, 2017 10:53 pm
by frijoli
Thanks Scott!
I'll have to do it tomorrow... Long day.
Posted: Tue Nov 28, 2017 8:35 pm
by frijoli
diycncscott wrote: ↑Mon Nov 27, 2017 10:27 am
Hello,
2. Download the attached file: license-scott-985DAD4295AE-1005170145-pro-lathe.dat.txt
No go...
Posted: Tue Nov 28, 2017 8:36 pm
by frijoli
Hello,
No go...
Re: File Size Issue Lathe Pro version
Posted: Wed Nov 29, 2017 10:08 am
by diycncscott
I was able to re-create your issue. I have emailed you a new license that solves the issue to: cferriola@tri__.__.com
