Can I Run Two Servo Motors On a Single Axis In a Non-Synchronous Manner?
Posted: Sat Mar 29, 2025 7:37 am
Successfully retrofiited a Koike Aronson CNC Plasma Cutter to Centroid Acorn & Clearpath Servo Motors last year. Still on a learning curve but overall working pretty well! On to the next project......
We're a fab shop and I'd like to retrofit a machine to use as a CNC beam drill line. It's basically a three axis mill, but I'd need the table to also move over the X axis to get the required 20FT of travel (or more) along that path. The machine I'm considering currently has 10FT of travel for the head only.
Is it possible to set up Acorn & CNC12 so both the head and the table move along the X axis to get the required 20Ft of travel seamlessly? As an example, if 0,0,0 is at one end of a 20Ft beam on the table and I need to drill holes at 17Ft along the X axis, then the head would move 10Ft to one end of the table and the table would move another two feet to the correct position. Can Acorn/CNC12 be configured so all I do is program hole location and from a home position on the X axis the system adds & subtracts from the two servo motors to get to the correct positon.
Feedback is much appreciated. Thx.
