Acorn atc pulling tool? <Answered>
supermaxcnc
Post by supermaxcnc »
I got a my atc working great. Although once in a while it seems to pull the tool from the carousel. Almost as if it's rapiding up before releasing tool gripper. Is there a way to add more delay to signal. Or slow down the rapid from 590ipm. To like 50??
Re: Acorn atc pulling tool?
supermaxcnc
Sorry i always forget
report_3484E41C0C27-1003248579_2025-03-17_17-16-09.zip
(1.31 MiB) Downloaded 3 times
supermaxcnc
I lowerd my rapid to 200ipm now its perfect just have to modify the macro to lower speed??
supermaxcnc
Anyone know how to lower toolchange feed? somewere in m6 macro?
centroid467
Post by centroid467 »
You want to reduce the speed when it rapids to clearance height after releasing the tool to the carousel?
You can modify line 225 (under N650) in your mfunc6.mac.
Original is
G53 Z0
The G53 is a rapid by default so moves at max rate. To reduce the rate, you can specify an L parameter.
Reduced speed could then be written as
G53 Z0 L200
for 200 inches/minute.
supermaxcnc
Thanks!!
