12 tool ATC turrette
Maker1970
Post by Maker1970 »
I am currently working on a CR Onsrud retrofit with acorn. In the interest of sticking with 4 axis and saving myself some width in the shop, as this thing is massive, I have decided not to use the turrets that I have. I acquired 2 of these turrets with this auction lot. They are pretty complete save, for the motor to drive them. Requires something with a 34 frame. Stepper or closed loop anything works just fine. Has a 10-1 gear reduction as part of the assembly. Currently has a 63f setup on it, but this can be changed to anything.
This thing is way over built. If you intend on putting it on a light weight gantry, its not for you.
Make offer, again I have 2 available.
Dennis@thehomesteadworkshop.com
Maker1970
"You lie to your friends, and I'll lie to mine. Let's not lie to each other"
