Z-axis error <resolved>
tuffduck
Post by tuffduck »
Hi,
I just installed the latest version of CNC12, V12.52. When I went to run a spoilboard surfacing program I received "z-axis travel exceeded". It is the same program I ran earlier in the day with V12.5. Not sure what is going on. Any help would be greatly appreciated.
report_E415F6F250EF-0205202948_2024-12-05_19-00-55.zip
(1016.1 KiB) Downloaded 1 time
Sword
Re: Z-axis error
Post by Sword »
Your work coordinate and machine coordinate for the Z axis are both 0.0000. Looks like you may not have set your WCS #1 Z axis location before starting the file. It's exceeding the travel when attempting to apply the tool length. If it didn't happen there, it would happen on lines 34 and 35 too.
Scott
tuffduck
Re: Z-axis error
Post by tuffduck »
I homed the machine, moved it to the centre of the machine, set xy to zero. Then started the program. I am using CHIPS, the program terminated before the tool touch off process. It has worked before, so not sure.
RogDC
Re: Z-axis error
Post by RogDC »
tuffduck wrote: Thu Dec 05, 2024 10:03 pm I homed the machine, moved it to the centre of the machine, set xy to zero. Then started the program. I am using CHIPS, the program terminated before the tool touch off process. It has worked before, so not sure.
Are you using the latest version of CHIPS 2.2 for CNC12 5.2?
Re: Z-axis error
You have not measured the offset for tool 1
Parameter 3 is set to 6 so the tool offsets must be a negative value.
With the same settings 5.1 or any older version will give you the same error.
tuffduck
Re: Z-axis error
Post by tuffduck »
No, I do not have CHIPS 2.2
Re: Z-axis error
To learn the basics of part and tool setup, the first place to look at is the manual ....
tuffduck
Re: Z-axis error
Post by tuffduck »
Thank you
RogDC
Re: Z-axis error
Post by RogDC »
tuffduck wrote: Fri Dec 06, 2024 2:08 am No, I do not have CHIPS 2.2
Contact Swissi for an update. There are alot of changes in CNC12 5.2 and beyond.
tuffduck
Re: Z-axis error
Post by tuffduck »
Thank you
