Can an Acorn be run from a laptop?
I see no real reference in the search.
Dell laptop is an i7-6500U@2.50GHz
16GB of RAM
It is running W10 Home
Would that be possible? I understand having to go thru the optimization process if that is possible with a laptop.
I remember issues with Mach mentioned.
I just ordered the Acorn and Pro upgrade for the mill.
16GB of RAM
1st Acorn project. G0704/BDTools/Hoss Conversion De"maching"
Leadshine MX 3660
Repurposed above Acorn (#194) and an Ethernet 1616 to a UMC-10 with an 8 position tool changer.
CNC12 Pro/Digitizing ver 4.64 (1/31/2022)
Leadshine MX 3660
Re: Can an Acorn be run from a laptop?
Should be fine with that if it meet the specs.
Clay
near Winston-Salem, NC
Thanks Frijoli. That is kind of what I expected.
I will see if all of the options to disable features are the same as a desktop during the optimization.
Leadshine MX 3660
Leadshine MX 3660
Welcome Fastest, it's good to see you over here in the Centroid world.
I've always enjoyed your posts on the other forums and look forward to your contributions to the Acorn knowledge base.
I hope the laptop works out well. I never thought about it 'til now but when a 2nd Acorn is purchased for my new mill project, it'll help when setting up the software with the CNC12 Wizard. It'll help me to be able to take the Wizard software to work & do some setup stuff during slow periods. AFAIK, Acorn is linked to 1 PC at a time. That's the only thing I miss about Mach so far.
Milton in Collierville, TN
Good to see you too DB!DICKEYBIRD wrote: ↑Sat Nov 04, 2017 8:58 am Welcome Fastest, it's good to see you over here in the Centroid world.I've always enjoyed your posts on the other forums and look forward to your contributions to the Acorn knowledge base.
I hope the laptop works out well. I never thought about it 'til now but when a 2nd Acorn is purchased for my new mill project, it'll help when setting up the software with the CNC12 Wizard. It'll help me to be able to take the Wizard software to work & do some setup stuff during slow periods. AFAIK, Acorn is linked to 1 PC at a time. That's the only thing I miss about Mach so far.![]()
I have been having too much difficulty keeping XP and Mach alive without problems.
Everyone seems to be pretty pleased with the Acorn. I would like to be able to machine something instead of constantly looking for solutions regarding computers.
I do have a sweet little computer I built for Mach but doesnt meet the requirements for the Acorn but my laptop does.
Though no one ever recommends using your CNC computer for other things, we all do. I am hoping it will work til I buy or build a NUC.
Leadshine MX 3660
Leadshine MX 3660
A laptop at work no problem as long as it meets the minimum requirements or is very close I would highly recommend installing an SSD though and be sure to turn off laptop specific features like power savings and going to sleep that sort of thing.
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Helluva nice laptop for Acorn!Fastest1 wrote: ↑Fri Nov 03, 2017 4:08 pm I see no real reference in the search.
16GB of RAM
Watch ebay for the Lenovo M92P tiny. If you can find one loaded with Win10 a plus, if you can find one with built in WiFi (look for the antennas on the back) double plus. They use standard 2.5" SATA drives so easy to swap to SSD. CPU is Intel 1151 socket mounted. Nice and compact. You can usually score one around $200 ish.
Then ASUS VT207N 19" 16:9 wide angle monitor you are set. Asus does make a 15.6" version VT168H but not much less than the 19", but might be better suited to smaller machines. I have two of them, one on a Dyna DM2400 the other on a D&M4 CNC Mill (Based on the Sherline CNC mill with an enclosure)
Welcome, you are going to like hardware (with TRUE spindle encoder input) and software from the same manufacturer doing CNC control for over 30 years! Do you still have your DM3000?
Marty, Yes I still have the DM3000, It sits in the corner and haunts me as to its potential. Especially after seeing some beautiful conversions, those always discourage me, make me realize what I dont know and inspire change.
In fact after hitting the buy now button on the Acorn and the Pro mill, I realized I might want to use it on that lathe instead. I would think moving from pro mill to pro lathe wont be an issue. In the end most likely run a few Acorns.
My 0704 is running Mach or was til I built a new pc and apparently dont have any legal XP copies around. I am stuck in a endless activation loop. I cant seem to find any solution online. I am thinking about buying an unopened licensed copy and install it. The pc I built works great with Mach and XP via the PP.
Oh and the laptop was just what I had and wont be solely used for CNC. Most likely til I get a NUC or something with a small form factor like you suggested.
Leadshine MX 3660
Leadshine MX 3660
I would suggest starting with Mill first.
There is actually a user working on his DM3000 now. I have a DM3000 as well (long story) and will get around to finishing.
Really, do the mill first.
How is your mill configured? What motor drives and motors?
Baby steps....we'll get you there. If Dickeybird can do it anyone can!
The set up and all looks very straight forward.
I was looking thru the options with the wizard even though I dont possess the Acorn yet.
The 0704 is running an MX3660, (2) 570 oz 23's and a 960 oz 34. It has limit switches on all axis' etc.
In regards to the other DM project going on. I wonder if he or she is attempting bidirectional tool changes? The turret is able to do it if you power the pawl. In the past everyone has been unidirectional.
I wonder if I can use the switches in the turret though I have no idea how they work or reference?
I really just want to move forward again. I am tired of having a small shortcoming in systems. This all looks promising.
Leadshine MX 3660
Leadshine MX 3660
