411 Error No Y Axis Movement
Posted: Fri Aug 02, 2024 12:56 pm
by rallispec
We have Bridgeport CNC with Centroid M400 retrofit done roughly 10 years ago. Today while running a program the machine stopped and set a 411 error and has since stopped working in the Y axis and will set the same error immediately every time when trying to jog Y axis. There is no movement at all no matter how slow. We performed the following diagnostics
1. Verified Y axis and motor moves freely by rotating the belt by hand
2. Checked VM+ to VM- voltage and it is 160VDC
3. Checked all fuses and none are blown.
4. Reversed the X and Y axis encoder and motor cables at the Allin1DC board. Doing so allows the Y axis to move without issue and X axis becomes the one to set 411 error code.
Please let us know where we go from here?
Re: 411 Error No Y Axis Movement
Posted: Fri Aug 02, 2024 2:47 pm
by Mattwo_support
Based on the information you provided. (assuming you checked F2, F3 and F4, Removed from the board and with a continuity meter) Your Allin1dc will unfortunitly need to be sent back for repair or swapout. Please contact Support@centroidcnc.com to arrange a RMA.
Posted: Fri Aug 02, 2024 4:13 pm
by cncsnw
This is a good and useful test. But when reporting your results, it is important to distinguish between the X and Y axes on the control, and the X and Y motors and axes on the machine.
I am guessing that you you mean is that, with connections swapped:
1) Pressing X axis jog buttons causes the Y servo motor to move, without error.
2) Pressing Y axis jog buttons causes no movement of the X servo, and results in a "411 Y axis(2) full power without motion" stall.
If that is the case, then Matt's analysis is probably correct.
However, because you do not have your Y axis limit switch input numbers entered on the Machine Configuration -> Motor Parameters screen, you could also get exactly this behavior simply by opening both Y axis limit switch input circuits (e.g. cutting the limit switch cable).
