Acorn Lathe removed ATC
Clausing2020
CNC Control System Serial Number: 3639
Post by Clausing2020 »
Hi Guys I have an Issue with one of my lathes. I had a ATC on the machine and I went back to a tool post and now when it gets to a tool change it states. (Turret Invalid Position, Re-Initialize ATC Press Cycle Cancel to stop Program) I think I have the Parameters Changed back to non ATC use.
report_0035FF8FFBA9-0820203639_2024-06-16_14-27-21.zip
(1.25 MiB) Downloaded 5 times
Re: Acorn Lathe removed ATC
You probably just need to delete the "cnctch.mac" file.
would be a good time to install the latest version of CNC12 v5.1 and reconfigure using the Wizard.
