Tool touch off and probe help needed
gregfox
Post by gregfox »
Hey guys, so I am not sure why I can't seem to get this to work how I want it to, but I feel like someone here might be able to help me.
So I would like to be able to probe my top Z zero for my G54 work coordinate and have it so all of my tools that I touch off on my fixed tool touch off are set to that Z zero point and I can't seem to get the settings right or something just isn't working properly. Does anyone have the proper settings in the wizard or parameters that may be messing me up here?
I appreciate any and all help a ton.
-Greg
Re: Tool touch off and probe help needed
Please tell us what is happening and why it's not working? What macro are you using? Please post a current report from the machine and/or the PDF
with all your current wizard settings. We can't really help unless we know how you are setup and what is or isn't happening.
Open the wizard press CTRL P and save the pdf to the desktop and then post it and/or a report here.
There are several macros on the forum to do exactly what you want. This is an old topic with a lot of info.
https://centroidcncforum.com/viewtopic. ... &start=160
gregfox
Post by gregfox »
I will post the report after work and take a look at that post thank you.
gregfox
Post by gregfox »
Ok so here is my report. Can anyone fix it up for me to do the above? I will pay anyone if they know how, lol.
report_20D7787C5DA2-0724237403_2024-04-30_15-19-43.zip
(1006.45 KiB) Downloaded 7 times
how about some photos of your machine/setups, wiring etc.. what kind of probe? is it NC or NO? what kind of machine is this? knee mill? bed mill? make a photos album with lots of photos. post link here.
and initially its easier for us to see your Wizard settings sometimes so open the wizard and press CTRL P and post the PDF it generates here.
there is a selection in the Wizard TT menu that tells CNC12 that you want to use the Probe as a reference tool.
A side note here, looking at your report, I'm not sure how you came up with your steps per revolution. You have them set to 25,400 on the X and Y and 40,650 on the Z axis. Can you share how you got those numbers as those are incorrect settings for Acorn and your drives.
What drives are you using?
And as I mentioned before and Keith also stated, open the wizard and press CTRL P and post that PDF here.
You have other issues to fix first before you go further.
What is the macro number for your tool touch off macro?
gregfox
Post by gregfox »
Ok so i have a pm 728vt Mill.
-X and Y axis have STEPPERONLINE High Torque Nema 23 CNC Stepper Motor 114mm 425oz.in/3Nm CNC Mill Lathe Router and TB6600 Driver ST4045
Here:
https://amzn.to/4b8Vszo
and
https://amzn.to/4dlTe1p
-Z axis has a Nema 34 Stepper Motor 6A 12Nm (1700 oz-in) 156mm Length for CNC Router Mill Lathe with STEPPERONLINE CNC Digital Stepper Motor Driver 2.4-7.2A 18-80VAC or 36-110VDC for Nema 34 and 42 Motor DM860T
Here:
https://amzn.to/4aYWHRS
and
https://amzn.to/4aUAEfh
-Probe is a PGFUN CNC 3D Touch Probe Upgraded XYZ Axis Anti-roll Edge Finder Waterproof 3 Coordinate Measuring Sensor Kit with 6mm Shank & 6.5 Ft Cable, Compatible with Mach3 (Edge Finder-NO)
Here: https://amzn.to/3JFzmIX
-Tool Touch off is a NC located
Here: https://amzn.to/3UGzUVx
Pictures(not very good, but) here's some:
gregfox
Post by gregfox »
I will do the PDF after dinner just give me about an hour.
gregfox
Post by gregfox »
I cant figure out how to do the pdf, it wont preview it at all for some reason. what else can I do?
