The ghost is back in the machine
Re: The ghost is back in the machine
The entire system was rewired from scratch, replaced the beagle bone, improved wire management, added a grounding bar, a DB25 board, EMI filters, replaced a faulty drive, tested each component one at a time and left everything turned on overnight. As soon as wee connect the step and direct wires are connected up for the x direction drive, we get errors. Tested with an additional motor, ethernet cable and computer, same result.
Could there be a problem with Acorn where step and direction connect?
Any ideas?
Any ideas?
- report_E415F6F250EF-0205202948_2021-07-29_21-05-33.zip
- (2 MiB) Downloaded 78 times
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Please post manual for your drives.
Is it only X or Y and Z as well?
Describe how you have the drive wired to Acorn
It is only X. Y and Z are okay. Only 6 wires from the drives wires are going from DB25 are connected to Acorn.
- GR214V Manual (1).pdf
- (848.59 KiB) Downloaded 69 times
If X is rewired exactly like Y and Z. Then I wonder if the X drive is suspect. So you can remove X drive and your comm problems go away for sure? Y and Z left on?
The drive is brand new. Tried a different motor same result. If the drive is wired to Y or Z, no errors.
I have tried the 3 motors with the different drives without errors until the wires for step and direction are connected to x on acorn. Is it possible to swap X for the 4 axis to see if it is Acorn?
Yes, give it a try, just set Axis 1 to N set Axis 4 to X
Thanks, i will give a go tomorrow.
Also, try wiring the Y or Z drive into the X pins to see if it's the pins or the drive
Testing a program now. I have had everything connected and on without errors for 16 hours.
