acorn with an old shopbot
Re: acorn with an old shopbot
I know that I was just wondering if anybody else has had that happen.
well I have a new problem. I decided that the control box I had was a little on the small side so I got a new box and rewired it. Now when I turn the unit on the board is flashing and no heart beat.
Disconnect EVERYTHING from Acorn except for power and see what you get when you turn it back on.
when I disconnect my db 25 breakout board I still get the flashing and no heart beat. the 2 blue lights on the Beagle board flash on and off but all the switch lights do to
Power supply short circuit
Something else is connected
Right now the only thing connected is the main board and output switches still the same.
Nothing else but the Acorn is connected to the Acorn's power supply? If it is the supplied MeanWell, then the green LED will likely blink if short circuit protection is activated.
When you say green LED do you mean the one on the board by the mounting hole and the end of the output LEDs
I was referring to the status LED on the MeanWell power supply itself. It should turn on momentarily when it tries to restart from short circuit protect mode then turn back off if the condition persists.
I am not getting any lights on my power supply the only LEDs are on the board
