Page 8 of 17
Re: Tool Setting Options For Routers and Mills
Posted: Tue Jan 22, 2019 5:29 pm
by Dan M
cbb1962 wrote: Tue Jan 22, 2019 4:58 pm
Dan M wrote: Mon Jan 21, 2019 9:21 pm
If you know of a way to do this in one cut file please let me know.
You could edit the files together if it's for a production run - that's what I did before I figured out how to do it from Fusion, but it wasn't worth the time for one-off jobs.
There is a lot of things that I REALLY like about V-Carve Pro, vs. Fusion, but how V-Carve handles WCS isn't one of them.
Thanks Clint, and right now everything I do is a one off job. I'm just going to not worry about it for now and just run a separate file for the profile cut out tool paths. That's one of the things I like about Vcarve is its super fast to make a tool path. Maybe once I've been using the software for a few I'll figure out what Gary was talking about.
BTW thank you very much for the macro, it works great and now I have a better understanding of how everything works.
Dan
Posted: Fri Mar 15, 2019 12:25 pm
by todd432
cbb1962 wrote: Tue Jul 10, 2018 8:45 am I was able to combine both macros into one.
Option 0; skips setting Z0 - uses current Z0
Option 1; Jog to the movable touch plate, set Z0, move to fixed TT1 record offset to #159, move back to tool change position.
Option 2; Automatically move to fixed TT1 and set new tool's Z0 using #159 offset, move back to tool change position.
mfunc6_all_in_one.mac Save as : c:\cncm\mfunc6.mac
Hi
I like using your macro ,the all in one
So recently I got a CWP-4 Pendent Wireless from Centroid.
I set it up per their instructions, and it works.
Except for this macro , I get all the way to jog over movable touch plate (option #1), when I start jogging with the new pendent it jumps to the m6 line in the g code.
I lose the cycle start prompt, to start the prob.
I really like the pendent, I was using the X box 360 and it worked fine. I really like the allinone mfunc6 macro too.
Any thoughts
Todd
Posted: Fri Mar 15, 2019 7:16 pm
by slodat
Has anyone looked at what this M6 Macro will need for CNC12 4.14?
Posted: Fri Mar 15, 2019 8:05 pm
by cbb1962
If I had a sneak peek at V4.14 I would. ;-)
Posted: Fri Mar 15, 2019 8:13 pm
by cbb1962
todd432 wrote: Fri Mar 15, 2019 12:25 pm I get all the way to jog over movable touch plate (option #1), when I start jogging with the new pendent it jumps to the m6 line in the g code.
So, did it work properly for you before the pendant? I have no idea why it would do that...
Posted: Fri Mar 15, 2019 8:31 pm
by slodat
cbb1962 wrote: Fri Mar 15, 2019 8:05 pm If I had a sneak peek at V4.14 I would. ;-)
It has been released!
viewtopic.php?f=60&t=2894
Posted: Fri Mar 15, 2019 8:41 pm
by todd432
Hi
It worked grate before the pendent.
I got it to work after I posted , I had to change the Z direction during probing.
I only used it one time after I got it to work on a job. So fingers crossed
I doin't know if when you activate the pendent in the wizard if it changes some parameters or not.
I think some of it was me lol.
Posted: Sat Mar 16, 2019 10:52 am
by GBCues
Can someone please verify that cbb's macro works with 12.4.14? I like to keep up to date on the new releases, but his M6 macro works too well to abandon.
Thanks in advance
Posted: Sat Mar 16, 2019 3:57 pm
by slodat
It's working with CNC12 4.14 for me!
Posted: Sat Mar 16, 2019 4:43 pm
by Dan M
slodat wrote: Sat Mar 16, 2019 3:57 pm It's working with CNC12 4.14 for me!
Nice, I've been holding off on the update until the macro was working on 4.14 . Any one else have it up and running?
Dan
