Page 6 of 7
Re: Cheap CNCPC that meets requirements: Lenovo Think Center M92P for Acorn <updated model M93P>
Posted: Wed Apr 12, 2023 12:04 am
by Sword
dustboy wrote: ↑Tue Apr 11, 2023 8:26 pm
Ordered a "renewed" M93P on Amazon, it is NFG, no boot, seems like disk issue (the blue screen of death told me so). I'm afraid we are scraping the bottom of the refurbishing barrel on this model. I'm one of those dumb "Apple" guys who doesn't understand the "Quad-encabulator Raizen i97 6900T 1.21 jigawatt" lingo, so I'm leaning on you guys for a recommendation. What's next?
Either return it to Amazon, or you could try creating a bootable USB drive to attempt to diagnose it, or reinstall Windows with it. You'd probably need to enter the BIOS to make sure it is set to boot from USB. It did come with a hard drive/SSD? Many are sold without, and you need to make sure.
Posted: Thu Apr 13, 2023 11:20 am
by dustboy
I made a USB recovery drive on my router PC and ran a clean install twice, unsuccessful. Something is wrong with the hardware, so back it goes to Scamazon. One of the USB ports was bad too, so that is reason enough.
I ordered a refurb NUC i5-7260U for a bit more money on fleaBay, based on Centroid's recommendation. Looks like it benches at 1,993 which is almost double what is required for a lathe.
Re: Cheap CNCPC that meets requirements: Lenovo Think Center M93P and HP G3
Posted: Fri Jun 02, 2023 5:10 pm
here is another.
HP Micro Desktop Computer 800 G3 Elitedesk Mini Business PC
https://amzn.to/3NamUna
Posted: Wed Jan 10, 2024 9:46 am
by glbreil
Hello Everyone one, since it looks like the NUC numbers and availability change everyday, if you were shopping for a NUC type today what would you buy?
Thanks Gary
Posted: Thu Nov 14, 2024 4:02 am
by Houseman303
lenovo ThinkPad W540 Works great for CNC control and CAD/CAM at the same time
Posted: Thu Nov 14, 2024 7:45 am
by ShawnM
The Intel NUC is way overpriced and you are paying for the name. There are dozens of 1L pc’s on the market that are a 1/2 to 1/3 the cost and just as good or better. This topic lists many of them if you read through it. Just be sure to get one that meets the Centroid minimum pc specs. Lenovo, HP, Dell, Beelink are just a few.
Posted: Thu Nov 14, 2024 6:44 pm
this is the one we recommend if you are going to buy new and diy it,
https://amzn.to/49ey9D7
be sure to run the free Centroid PC Tuner on any PC that is destined for CNC duty!!
Re: Cheap CNCPC that meets requirements: Lenovo Think Center M93P and HP G3, Beelink
Posted: Sun Feb 16, 2025 10:31 pm
by jhnmdahl
For the Beelink Equ12, the single core passmark for the 1220p ($259) is 3380 and multithread is 14520, while the 12450h ($309) single core passmark is 3352 and multi core is 16728. I bought the cheaper 1220p with the higher single core performance, and have no complaints, and appreciate that I have some "headroom" should it be needed in the future.
Posted: Mon Feb 24, 2025 2:03 pm
by MartinC
Just purchased a Beelink N100 mini-PC, a S12 pro mini
https://www.amazon.de/dp/B08DFL2L1F?ref ... asin_title
I don't have an Acorn yet so I can't say for certain if it will work. Single core benchmark should be plenty. PC tuner says it should be OK (except for the missing Acorn board of course).
Is there a mode to run CNC12 without controller board connected?
Cute little machine. Jaw-dropping value for money I'd say, €170 for the PC including 16G RAM, 500G SSD and Windows 11 pro. They don't advertise the Windows license, but I reinstalled Windows 11 and the installer did not even ask for a license, so it found something in the BIOS maybe? Worst case I'll need to purchase a license later.
Installation was not without problems, would not boot from USB stick (Win 11 pro was preinstalled, but I wanted to get rid of that in case crap- or malware was installed). Ran installer from USB stick after Windows had booted (which worked fine and I told it to do a clean install). Boot still shows Beelink icon so it was not a total wipe (maybe the logo is stored in the BIOS). Finding drivers for the chipset was also a bit painful, although most of the peripherals are supported natively by W11. This one will replace my HTPC, I'll get a second one for Acorn once I get around to it.
Compared to this unit Asus (formerly Intel) NUCs are totally (2-3x) overpriced.
Posted: Mon Feb 24, 2025 3:44 pm
by suntravel
You can use the offline version without a connected board.
