Acorn CNC12 version 4.5 has been released!
Devlin
CNC Control System Serial Number: 78047384ad00-0221191675
Re: Acorn CNC12 version 4.5 has been released!
Post by Devlin »
Hickory!
Devlin wrote: Wed Jan 06, 2021 4:29 pmHickory!
that name has been taken for the ethercat board. :D
milling
CNC Control System Serial Number: 3859
Post by milling »
Is Centroid coming back with software that will be able to import .dxf files?
milling
Post by milling »
Keith, I just got a response from the diysales mailbox and they said that the .dxf import capability will be incorporated into the next version 4.6. Is this true? If so when will that be released.
cbb1962
Post by cbb1962 »
cnckeith wrote: Wed Jan 06, 2021 4:52 pm
Any update on hickory? I'm beginning to see "Inexpensive" Ethercat Servos and Drives becoming available.
Clint in NW Arkansas
milling wrote: Mon Jan 11, 2021 11:12 am Keith, I just got a response from the diysales mailbox and they said that the .dxf import capability will be incorporated into the next version 4.6. Is this true? If so when will that be released.
you can use it right now,its in the beta, viewtopic.php?f=60&t=5079
milling
Post by milling »
I did install the BETA version and it did seem to import the file. The problem is it does not come in very well as gcode. Does autocad have to be set up a certain way to import smoothly?
milling wrote: Tue Jan 12, 2021 12:20 pm I did install the BETA version and it did seem to import the file. The problem is it does not come in very well as gcode. Does autocad have to be set up a certain way to import smoothly?
lets move beta talk to beta thread.. you'll have to post your .dxf file and screen shots for me to comment, in general the dxf file should only consist of Lines and arcs. if you have curves in the dxf file intercon doesn't know what to do with those!
Intercon reads DXF files up to and including version R14. At this time, only point, line, arc, circle, polyline and
lwpolyline entities can be used to create Intercon operations. All other entities such as text must be converted to lines
and arcs for them to appear in the Intercon Import DXF menu.
https://www.centroidcnc.com/downloads/i ... dxf-in.pdf
