Joey,
I’m trying to use a primeweld plasma cutter that has a Cnc port with 50:1 voltage. I see you mentioned the voltage should not be above 10 volts. Do you know the max current the tx board can handle? I read 2.5 volts but if the current is too high I don’t want to blow another tx board!
Also is there a board you could recommend that we could put before the input on the tx 50:1 for overcurrent protection? I think since so many boards have been burnt because of non-hypertherm maybe we could put some type of protection before the input on the tx board?
Thoughts?
Thc problem < non hypertherm build >
Re: Thc problem < non hypertherm build >
I answered my own question, I see you have done testing with the primeweld and it’s to loud of a signal. So I won’t buy that plasma to see if it works cause it seems you already tested it.
- Plasma/Laser Lead
We have tested the Po labs board with the Prime Weld Cut 60 (there latest generation of Cut 60) without success.
I haven't heard of any voltage divider board success's yet for use with Prime Weld Cut 60.
Use a Hypertherm for success.
Hey there its me again.
Happy to announce that my plasma is working great with the thc for two months now.
To make it work I've purchased a voltage divider because the voltage divider in my Chinese plasma was giving me a lot of trouble, and purchased another tx board cause I've destroyed the voltage reading of the previous one, and that did the work!
I would like to thank you guys for the help! Couldn't do it without you all!
I have a question... the tx board voltage reading, what type of signal does it reads? Is it an analog signal? Or digital signal?
- Plasma/Laser Lead
Wow you finally did it! Please share what voltage divider card you used. And please post a fresh report. I would like to look at the plots from the THC.
I think you might be the first customer to be running a Chinese cutter with our THC!. Congratulations!!!
