Dual Y gantry CNC router slowly getting out of square
Re: Dual Y gantry CNC router slowly getting out of square
I've even seen CAT6 bulk wire where each twisted pair was foil wrapped then all four pairs wrapped again with a drain wire. You can even buy the stuff at Home Depot.
But I just read back a little and you are using the Teknic cables and these are Clearpath motors. I was suggesting CAT5 or 6 for standard stepper drives.
I see you started another thread/topic about shielded cables, it would be more helpful if you keep all your questions in one thread/topic for your build so others can follow along.
Regardless if I have braid and a drain wire, or just braid, I always terminate them by soldering on a pigtail to the shield or shield+drain and heat shrink the connection. Sometimes I'll just comb out the braid, twist it and cover with heatshrink for smaller cables IF they have a high quality, dense braid.
Notice the larger yellow wires on the MPG/Panel/Probe connectors (soldered connection is bent back over the jacket and is the lump under the heatshrink) and the two green/yellow wires on the orange VFD cable. The VFD cable has a shielded twisted triplet for 3-phase power, and two separate individually shielded twisted pairs. One for winding over-temp sensors, and the other for fan power. Hence the multiple shield wires.
ryanjg11
CNC Control System Serial Number: 402E71ED62A8-0322214540
Post by ryanjg11 »
Tom, where are you terminating the shield/drain in the picture above? I can't quite see.
They should all be grounded to a common buss bar in the cabinet like in the pic below.
ryanjg11 wrote: Fri Feb 25, 2022 10:18 pm Tom, where are you terminating the shield/drain in the picture above? I can't quite see.
The shield wires to the VFD terminate to the green ground bus below the VFD. The shield wires to the signal connectors terminate to the ground connections on the individual connectors.
NicolaF
Post by NicolaF »
Hi everyone, I am experiencing the same problem. I have a cnc with dual Y axis, closed loop nema on each axis , and some chinese controller with a mach 3card. I have 25mm ballscrew on each axis. I seem to lose to 2-3 mm one side of Y everytime I run long g codes that involve lots of movements to bore 50 holes or so. As above, if I simply run the macine back and forth, there is no problem. Did anyone find a solution or encountered a similar problem?
Chaz
Post by Chaz »
Please start your own thread, this one is 3 years old already. You also state that you have 'some Chinese controller with Mach 3'? If so, sorry, we will struggle to help as this is for Centroid products .... There would be other forums better suited to help.
