Page 4 of 4
Re: Missing Steps in circular interpolation
Posted: Sun Feb 27, 2022 6:32 am
by suntravel
Well after changing a bunch of things i cant remember all.
At first i would take care of the wiring with snubbers, EMI Filters and shielded wiring.
Quick check if the PC is the cause, make a backup of CNC 12, get a fresh PC, configure Windows after the manual from Centroid, install CNC12, restore the backup.
If the resends are gone this way try to make a fresh Win 10 install with fresh updates on the old PC, fresh CNC12 install, restore backup. If resends occurs again on the old PC try to work on the network and hardware settings, or discard the PC as not ok for CNC12
Posted: Tue Mar 01, 2022 2:19 pm
KWORK wrote: Sun Feb 27, 2022 4:41 am UWE thanks for reply
I spent some time searsing the forum, dit not find the right answer.
Can you remember what to change in pc setup or is it in forum.
Will like to set the orginal power back and check it out.
Thanks for your time.
Knud
resend errors solution is here. https://centroidcncforum.com/viewtopic.php?f=61&t=1451
