Stepperonline wiring for CL57T drive to ACORN CNC controller
Bob.m1776
CNC Control System Serial Number: 8648
Re: Stepperonline wiring for CL57T drive to ACORN CNC controller
Post by Bob.m1776 »
Pat,
Glad to hear you got everything working. I have the same kit with 3 axis for a mini mill conversion. Your post helped me get to a successful setup and bench test of one motor.
I do have a question about how you have the "brake" terminal on the driver. It appears to be a purple wire. Is it hooked to a relay setup?
Bob
pat.lagro
CNC Control System Serial Number: E06234471BD4-0328248149
Post by pat.lagro »
Bob.m1776 wrote: Sun Dec 22, 2024 6:12 pm Pat,
Bob
Hi Bob,
I don't have a brake set up for any motors. The purple wire is my enable signal that goes back to Input 5 (IN5) on Acorn controller.
Pat
GBCues
CNC Control System Serial Number: noneC120192
Post by GBCues »
I recently got in a couple of new CL57T V4.1 drives and they now have a new entry in the signal block. After ALM+ there is now BRK and COM. There is no longer an ALM-.
Is this covered in a different thread?
Otherwise, FYI
Gary
In the manual of the driver....
The COM is the common negative for the alarm and brake. This is all outlined in the manual.
Jep, and to change from NO to NC use the software for the driver....
Chaz
Post by Chaz »
I'm looking for 'decent' stepper drivers for the 4 axis granite machine im retrofitting. Would these be recommended? Only 2 in stock in the UK but can order elsewhere if needed.
