Page 29 of 31
Posted: Thu Mar 07, 2024 7:17 pm
l3viathan wrote: Wed Jan 17, 2024 1:49 pm Here is a mostly complete preview of the VCP screen I'm working on.
nice look to it! i like it.
please post a fresh report.zip when you are 'finished' with it.
Posted: Mon May 27, 2024 6:14 pm
by Aplus
I think I have a Custom VCP problem I can't figure out. This is on an AllinOneDC. I have parameter 192 set to equal 7 which brings up circular pocket one shot. I'm using the Aux5 button, Skin event 9, and changed the graphic. This is the first time I used it to actually cut with and I want to use it again, however when I press the Aux5 key, it brings up my previous info in an intercon screen but not the original screen with the help graphics. It doesn't seem to reset after using it once.
Posted: Mon May 27, 2024 9:06 pm
by cncsnw
For better or worse, that is the intended behavior of the one-shot canned cycles: they retain the values you last used, in the expectation that the next time you use it, you will probably be doing the same feature, or something similar.
You should be able to show or hide the help graphics by pressing F5.
Posted: Fri May 31, 2024 8:13 pm
by Aplus
The only way I can get the help screen to appear is to go into intercon thru the Cam button then Icn button then it loads the circle oneshot program. Then I can turn on the help screen.
Posted: Thu Oct 24, 2024 3:46 am
by Philip Venter
Hi Team.
Can someone please assist?
I need a VCP for a 12 tool ATC Carousel Acorn Mill.
Current software version is CNC 12 Acorn Mill V 5.08 and I do have the pro licence installed.
Looking forward to your response.
Regards.
Posted: Thu Oct 24, 2024 3:19 pm
Philip Venter wrote: Thu Oct 24, 2024 3:46 am Hi Team.
Regards.
Install v5.20 and use the Wizard to setup the carousel.
start a build thread here is how. https://centroidcncforum.com/viewtopic.php?f=60&t=6928
make a photo album or your machine so we can see what you have. and post a link to the album here is how
Posted: Fri Nov 29, 2024 11:24 am
by mikes
cnckeith wrote: Tue Oct 22, 2024 7:47 pm New VCP features added to CNC12 v5.20 now available.
more info here.
Keith, when I try using the above link, I get the messages:
You are not authorised to read this forum.
Posted: Sat Nov 30, 2024 11:00 pm
by mikes
cnckeith wrote: Fri Nov 29, 2024 4:07 pm
mikes wrote: Fri Nov 29, 2024 11:24 am
thanks! i fixed the links in my post.
Sorry to say, but it's still giving me the same message.
Posted: Mon Dec 02, 2024 1:55 pm
hello. thanks! it was just a link to the v5.20 download an release notes, in the release notes there is information about new features added to the VCP.
release notes.
https://www.centroidcnc.com/centroid_di ... _notes.pdf
download page.
Posted: Tue Jan 07, 2025 12:56 am
by PFM Dave
Hello All,
So I just updated to 5.22 and to my surprise buttons on the VCP are now changed.
Spindle Clock wise, spindle counter clockwise and spin break are now gone.
I will figure it out but I don't understand why.
PFM Dave
