New Build - Starting from scratch with a Weiss VM25L (G0704)
- CNC Control System Serial Number: 544538046067-0616237327
Re: New Build - Starting from scratch with a Weiss VM25L (G0704)
I have measured it several times trying to get as precise as possible. All 3 axis are .0025 and I adjusted that out. I used several vids but this one mainly.
what do you mean by "i adjusted that out"
Good afternoon.
In the settings for lash comp. I first verified and made sure my motor revs were accurate and then set an indicator on the x, y and z axis and went one full rotation to zero on the dial and then backed off in the other direction noting the difference it took to move. I have double ball screws advertised and zero backlash but I have the exact same amount X, Y and Z and have taken the machine apart several times and measure no backlash anywhere other than the ballscrews. It runs great btw and seems accurate so far other than the strange not reading dead on zero at times when I return it, I thought at first I had my gibs too tight but checked and rechecked that as well.
@cnckeith - The previously mentioned issue was me not knowing I had the settings set to move in .001 increments and I was expecting to be able to land on .0001 at will pretty much. I changed the settings to .0001 and now I can adjust to any number I like however I discovered I think I have my gibs adjusted too tightly. When dialing in a tenth at a time it does not move then suddenly jumps a thousandth or so or at least several tenths. I wonder if I should disconnect my ball screws so I can feel the gib adjusting by hand?
On another note, I get a constant message on the screen about the 452 Ethernet error however it runs great without issues. Should I be concerned about this? I did isolate the network cable to be by itself and not by any power wires and it did not help, I have the excess in a loop lying in the bottom of the cabinet right where it comes out of the acorn unit.
yeah you are describing classic "sticktion"
mechanical stick - slip action which can be caused by a variety of things.
review this post to solve the communication errors.
https://centroidcncforum.com/viewtopic.php?f=61&t=1451
I just discovered my touch off tool (cheap amazon) is .007 off from my manual tool setter. Is there compensation for this in acorn or is just because it's cheapo import?
@cnckeith
I am hoping you can offer some wisdom on this issue. I have 18" of X travel. I placed a 10.3" part in the center and it will not allow me to set WCS for X on either the left or right side or probe as web I get travel limit warnings. To over come it I change the WCS in fusion to use the center of the part and it did the job that way. For good measure I rehomed and set every thing to zeros on that home trying to figure it out. Any ideas?
Thanks a
so much!
Thanks a
so much!
post the offending g code program
prove to yourself you have travel limits and WCS set where you want it by using MDI mode to eliminate g code issue produced by a cad/cam system
G1X0Y0 F20
G1X200F2 (should produce trave limit error message
G1X whatever amount you want that is the distance from wcs zero to just shy of the soft limit F20
etc
G1X0Y0 F20
etc
Thank you very much for your help. I am sorry but I am not sure what you mean. I am not confident in gcode at all. I exported just the facing op and put the WCS back to the lower left corner:cnckeith wrote: ↑Fri Mar 28, 2025 3:40 pm post the offending g code program
G1X0Y0 F20
etc
O1001
(T20 D=0.6329 CR=0. - ZMIN=-0.125 - face mill)
N10 G90 G94 G17
N15 G20
N20 G28 G91 Z0.
N25 G90
(Face1)
N30 T20 M6
N35 S3500 M3
N40 G17 G90 G94
N45 G54
N50 M7
N55 G0 X10.8037 Y-0.2324
N60 G43 Z0.6 H20
N65 G0 Z0.2
N70 G1 Z-0.0617 F1.132
N75 G18 G3 X10.7404 Z-0.125 I-0.0633 K0. F2.265
N80 G1 X-0.4204 F4.53
N85 G17 G2 Y-0.0502 I0. J0.0911 F3.398
N90 G1 X10.7404 F4.53
N95 G3 Y0.132 I0. J0.0911 F3.398
N100 G1 X-0.4204 F4.53
N105 G2 Y0.3141 I0. J0.0911 F3.398
N110 G1 X10.7404 F4.53
N115 G3 Y0.4963 I0. J0.0911 F3.398
N120 G1 X-0.4204 F4.53
N125 G2 Y0.6785 I0. J0.0911 F3.398
N130 G1 X10.7404 F4.53
N135 G18 G2 X10.8037 Z-0.0617 I0. K0.0633 F5.436
N140 G0 Z0.6
N145 G17
N150 M9
N155 G28 G91 Z0.
N160 G90
N165 G28 G91 X0. Y0.
N170 G90
N175 M30
hello.
a lot of newbies struggle with cad cam generated g code because they assume that the cad cam system is going to create good g code while simultaneously not under standing g code basics. so i'm invite you to learn a handful of basic g codes that will serve you well.
and i was suggesting above that you learn and use these basic g codes (G1 Xsomeposition F) to prove and learn to understand where your over travel messages are coming from.
so start by eliminating the use of the cad cam generated program.
and just command some simple moves to learn the see how they and the control will act (based on your settings).
once you wrap you head around that, then introduce the unknow of the cad cam g code and things will be easier to figure out what going on.
this program is about 11.5" long in X. and uses G54 as the WCS position.
so you either have the wrong WCS set, or G54 is set on the machine in a position that doesn't have enough room to run this g code.
