Acorn not controlling DMM Servo (Added video to my post)
marks3465
Re: Acorn not controlling DMM Servo
Post by marks3465 »
Yes, I have tried everything. That's why there is a another cable attached to Y axis. Same thing Y+ works but Y- doesn't. The DRO shows movement but the servo doesn't move. The drive in this picture is a different one from the one I started with. Also tried new DB25 cable. The only good thing is I know the Wizard pretty darn good.
You've got me. Try a different ACORN?
marks3465
Post by marks3465 »
I'm thinking the same thing. Sending Centroid the info from this thread and a report. Thanks for your help.
if the DRO is moving then the Acorn is outputting steps. something in the DMM software setup is stopping you is my guess. post fresh screen shots.
marks3465
Post by marks3465 »
Here are screen shots of my setup.
are you using the dmm supplied cable or did you make your own? how about photo of your wiring?
also, looks like you didn't follow my instructions in the earlier post.
viewtopic.php?f=60&t=3512#p27086
marks3465
Post by marks3465 »
I did follow your directions, DMM went in and changed my settings. He used Team Viewer and made the changes. I told him I was advised to use the setting I had. As you can see by this photo I'm using DMM cable. Here is the wiring to Acorn. All I'm doing is bench testing at this point.
marks3465 wrote: Mon Sep 23, 2019 9:27 pm report_3403DE6F5004-0716192282_2019-09-23_20-23-25.zip
Update on bench testing,
I used Kieth's cheat sheet and it all worked. There is a box that can be checked in DMM software that will put the servo enable active low. By doing this you can leave the enable box checked in advanced settings in Acorn Wizard. You must also power down the DYN4 for any changes to take place. My last and only issue is my servo only turns one direction when I change to 400khz. If I stay at 200khz it works great. I hardly have anything connected to Acorn so I can't see how I have noise grounding issues. Any advice would be greatly appreciated.
then don't use 400khz , cabling and shielding has to be very good to use 400khz. If it works at 200khz then use that setting.
what kind of machine are you going to install this on?
marks3465
Post by marks3465 »
I'm upgrading a CNC Router Parts Pro. I eventually want to add ATC to it. What would be the difference in only using 200khz instead of 400khz.
DanielCA92563
Post by DanielCA92563 »
marks3465 wrote: Tue Sep 24, 2019 8:38 pm Update: I wish I had good news but still can't use 400khz pulse rate. DMM has a feeling that Ver.4 Acorn has an issue with DYN4. I'm going to try a older version of Acorn. Has anybody else had any issues using Ver.4 Acorn with DMM DYN4?
I have a new DYN4 and Version 4 acorn. I’ll try to bench test tonight and let you know how it works at 400khz
