New StepperOnline CL57T V4.1 set up not turning <resolved>
GBCues
CNC Control System Serial Number: noneC120192
Re: New StepperOnline CL57T V4.1 set up not turning
Post by GBCues »
I went into the Wizard and reversed the Enable on Drive 2 just to check, but no go.
At this point, I'm going to go back to basics and pull a CL57T out onto the bench and wire up a single motor (ala Marty)
I also would like to get MotionStudio working. I connected the cable to my CL57T and found COM3 was active, but all I see is Drive Opening or something like that. No other menu items seem to do anything.
If all that fails, I will put one of the old HSC57 drives in and bench test with that.
This will all take me a while, but I'll be back
THANKS everyone!
Normal Workflow:
Connect power, encoder and stepper wires
Connect Motion Studio or other tuner for the drive
Test if the drive is ok.
If not find error
If yes connect to Acorn and test if the stepper is turning.
If yes, mount on the machine
Sword
Post by Sword »
You could disable closed loop mode with dip switch #6 and try them as open loop just to see what happens.
Scott
If the drive locks when you power it up you don't need the ENABLE line. Most all stepper drives are enabled by default. Very few are not.
As Ken mentioned, if the encoder is wired wrong the drive would fault internally when you try to move it and the red LED would blink on the drive 7 times.
Gary, if you switch SW6 to ON which puts the drive into open drive mode and not closed loop does it move?
Edit, Scott beat me to the test with SW6.
7 blinks = wrong encoder cable connected to the drive, and/or mixed up encoder wires, and/or mixed up motor phase connections.
GBCues
Post by GBCues »
I'm sorry guys, I haven't checked on this thread for a few days. Been trying different options. I will go down and follow these suggestions to see if it makes a difference.
I'll be back
GBCues
Post by GBCues »
OK
I gave up on the 5V Dir and Step connections and changed to 24V. I found that the motor would buzz when I clicked + or - and the motor was not locked up after.
So the tip that we don't need Enable if the motor locks up was helpful. I disconnected En+ and En-, powered everything up, loaded CNC12 and happily I now have smooth motion on one motor Yay!
There was some discussion earlier that I had EB+ and EB- reversed. I found this documentation on StepperOnline's site which explains why I did it the way I did. Not saying anyone is right or wrong, just why I did it the way I did.
Thanks everyone for the help.
Ewe I re-read your instructions. I didn't realize drive needed to be disconnected from CL57. So I will give that another try too
