4th axis motor trying to turn before brake is actually released
Allin1Chris
PLC Expert
Re: 4th axis motor trying to turn before brake is actually released
Post by Allin1Chris »
dbensavage wrote: Fri Dec 08, 2023 12:23 pm I tried adding G4 P1.5 to the next line under the M95 /4 and get no pause.
Hello, Can you create a new fresh report and send it so we can see the modifications you made. Adding a G4 should cause a small pause.
Taking your earlier provided report, i modified both your M10 and M11 with a G4 of 1.5 seconds and are attached here. Place them into your C:\cncm directory and that should work. If not then please send a fresh report.
mfunc11.mac
Added a G4 P1.5
(87 Bytes) Downloaded 46 times
mfunc10.mac
Added a G4 P1.5
(87 Bytes) Downloaded 39 times
When requesting support READ THIS POST first. viewtopic.php?t=1043
Please ALWAYS post a FRESH report. To make a report: https://www.youtube.com/watch?v=A36MSMilMyc.
Centroid PLC Tutorial Videos
dbensavage
CNC Control System Serial Number: 6200 on the All In One and 1814 on the Acorn
Post by dbensavage »
I tried the macros this morning and still no pause. Attached is a new report.
To test this i have been going to MIDI and typing in: M10 then cycle start to apply the brake. Then Typing in M11 A180 then cycle start and I get an "instant" stall with no pause before the stall. I even entered P3.5 into the macro and no pause.
report.zip
(174.27 KiB) Downloaded 24 times
Your mfunc11.mac file turns off output #4, but your PLC defines out6 as clamp. Which output is the clamp solenoid connected to?
dbensavage
My machine is setup so M10 turns on the brake (closes output 6) and M11 Releases the Brake (Opens output 6).
If you enter
M11 A180
on one line, then the axis motion (A180) is performed before the M function (M11).
To do what you intend, you have to run the M function, then run the axis motion on a subsequent line:
M11
A180
dbensavage
It sounds like the PLC program is wrong then. The "board" has output 6 labeled as the clamp so that's what its hooked up to. How do I go about changing the PLC program? and, why does the brake lock and release if the macro's both say output 4?? Now I'm really confused.
dbensavage
CNCSNW,
You were correct, after doing it on the second line the pause is there. THANK YOU!! I just ran a test program center drilling on 3 sides of a part and it worked great!
This is not correct. The M10/M11 macros and the PLC program use M function request #4 (SV_M94_M95_4) to control a "Clamp" output on OUT6.
M function request numbers do not have to match either the M function number or the affected output. They are just a bucket of available bits, that can be used for any purpose in any order.
