Page 2 of 7
Re: homing travels in wrong direction
Posted: Sat Nov 11, 2023 2:11 pm
by suntravel
Axis 1+2 ar searching home in negative direction, if you want them to run in positive direction, change to M92
CTRL+P in the Wizard generates a PDF of all screens...
Posted: Sat Nov 11, 2023 4:51 pm
by billybobron
Interesting this is how it was set when someone else helped, that contributes to what drove one of my responses in the past then I went silent for a while! I am going to try this now and report back shortly
Posted: Sat Nov 11, 2023 4:58 pm
by billybobron
I changed and ran it still travels in the same direction in the down ward direction! I did this as well yesterday as I had posted with the same out come I hit the EStop so that the spindle wouldn’t bottom out on the waste board see photo
Posted: Sat Nov 11, 2023 8:37 pm
by suntravel
If you jog Z in + direction, will it go up or down?
Posted: Sat Nov 11, 2023 10:41 pm
by RogDC
If you hit Ctrl+P while in the wizard it will generate screenshots of all screens. Print to Windows PDF and save, then post PDF file here.
Posted: Sat Nov 11, 2023 10:57 pm
by billybobron
It does go up and down with both controls
Posted: Sat Nov 11, 2023 11:15 pm
by billybobron
The PDF is attached, I need to go back and look at some notes of a conversation that I was having of this board, I seem to recall that I seem to recall I had a similar problem during original wire up I just don't recall exactly what it was I will be tackling that in the morning still don't have everything set like I want, I let the build go for several weeks without touching and now trying to complete everything when this popped up.
Posted: Sun Nov 12, 2023 12:45 am
by suntravel
billybobron wrote: Sat Nov 11, 2023 10:57 pm It does go up and down with both controls
That is not the answer.
Will it move up if you jog +Z ?
If not set Direction Reversal to Y
Posted: Sun Nov 12, 2023 6:47 am
by billybobron
Yes it travels upwards when toggled
Posted: Sun Nov 12, 2023 7:38 am
by suntravel
Then it will move with M92/Z L1 also upwards.
