homing travels in wrong direction
Re: homing travels in wrong direction
Axis 1+2 ar searching home in negative direction, if you want them to run in positive direction, change to M92
CTRL+P in the Wizard generates a PDF of all screens...
billybobron
Post by billybobron »
Interesting this is how it was set when someone else helped, that contributes to what drove one of my responses in the past then I went silent for a while! I am going to try this now and report back shortly
billybobron
I changed and ran it still travels in the same direction in the down ward direction! I did this as well yesterday as I had posted with the same out come I hit the EStop so that the spindle wouldn’t bottom out on the waste board see photo
If you jog Z in + direction, will it go up or down?
RogDC
Post by RogDC »
If you hit Ctrl+P while in the wizard it will generate screenshots of all screens. Print to Windows PDF and save, then post PDF file here.
billybobron
It does go up and down with both controls
billybobron
The PDF is attached, I need to go back and look at some notes of a conversation that I was having of this board, I seem to recall that I seem to recall I had a similar problem during original wire up I just don't recall exactly what it was I will be tackling that in the morning still don't have everything set like I want, I let the build go for several weeks without touching and now trying to complete everything when this popped up.
acornpdf.pdf
(1.27 MiB) Downloaded 24 times
billybobron wrote: Sat Nov 11, 2023 10:57 pm It does go up and down with both controls
That is not the answer.
Will it move up if you jog +Z ?
If not set Direction Reversal to Y
billybobron
Yes it travels upwards when toggled
Then it will move with M92/Z L1 also upwards.
