New build: Weiler 120CNC Retrofit on the cheap side / weiler ud24 with a 8 station turret
Re: New build: Weiler 120CNC Retrofit on the cheap side / weiler ud24 with a 8 station turret
It is hard to tell because I cannot find a datasheet or anything for them. Do you know if the outputs are differential quadrature?
the company is still around, i will try to find out!centroid467 wrote: ↑Wed Jan 17, 2024 4:47 pm It is hard to tell because I cannot find a datasheet or anything for them. Do you know if the outputs are differential quadrature?
thank you for linking to the thread
Hey seem to work, here is the data sheet
- Model60_B.pdf
- (341.12 KiB) Downloaded 39 times
- Model60_A.pdf
- (412.71 KiB) Downloaded 30 times
