Yes, elapsed time is indeed there. When a job is finished, if you happen to move the machine with arrows/MPG, the elapsed time is cleared, so remember to check it beforehand. I set up log file creation in my postp, so If needed, I can check to see what the time was and when it was last ran.
I seldom if ever use RTG, just don't like it. Now if it had something like this for a toolpath display, I'd use it daily...https://centroidcncforum.com/viewtopic. ... 315#p59315 That happens to be UCCNC's toolpath display.
Job Timer
Re: Job Timer
Scott
Re: Job Timer
When the job is running on my router with 4.82 and I'm looking at the cutting graph page there is no timer running, up or down. When I press F8 "g-code" and switch to g code screen view there is an elapsed timer counting up. When I press F8 "graph" again to go back to the graph screen there is no timer anywhere. Am I missing something?
Re: Job Timer
- when running a job, the g code Job actual run time is in the G code view in the upper right. just below the part counters.
- G code job time estimation is in the Graph screen (not in the run time graphics screen (RTG).).
- will add percentage / count down feature at some point. when we redo the RTG screen that would be a good time to add these types of features.
Re: Job Timer
This is for sure better than to run a timer appShawnM wrote: ↑Tue Feb 28, 2023 4:08 pm When the job is running on my router with 4.82 and I'm looking at the cutting graph page there is no timer running, up or down. When I press F8 "g-code" and switch to g code screen view there is an elapsed timer counting up. When I press F8 "graph" again to go back to the graph screen there is no timer anywhere. Am I missing something?![]()
