New Build - CNC Plasma Table
Re: New Build - CNC Plasma Table
I think he wants a touch screen now Keith. Not gonna get one of those for $99.
yeah the price and availability on touch screens now..yowww... resistives are hard to find now...
Planar works well
https://www.amazon.com/dp/B00009Q97Y/re ... B00009Q97Y
i've been building a collection here.
let me know if you have any favorites to add to this page.
Planar works well
Thanks Keith. Decided to forgo touch screen. I picked one up from Amazon.
I see that Centroid is using Sheetcam and there is a post processor available that Keith posted. I haven't seen one for Fusion 360 though.
Looks like a built a plotter. Checking turns ratio setting and gantry squareness. Looks pretty good as close as I can measure with a sharpie
post a fresh report.zip so we can follow along.
New report attached.
I'm trying to recalibrate Float Switch Z zero offset but when I trigger the float switch I get a 9101 Torch Breakaway error and have to cycle reset to clear the error. I don't have a Breakaway input defined.
- report_3484E41BC6EB-0511226197_2022-07-22_16-50-53.zip
- (3.84 MiB) Downloaded 41 times
First cut video on YouTube
The float switch also acts as a breakaway when NOT running a touch off cycle. This is outlined in the plasma manual.
In your video, did you cut the same line twice? It didn't even look like there was a pierce delay for your material.
I did read that in the manual and even made a note of it in my notes. It just didn't make the connection.
I did make a couple of failed cuts on the same line where the pilot arc started but never fired. Then I remembered the work clamp. I was using the Steel 45A .250 standard profile but don't remember what the pierce delay was set to. I will dig into it today.
