The ghost is back in the machine
tuffduck
Re: The ghost is back in the machine
Post by tuffduck »
Beagle Bone Green NO wifi. Remember you will have to load the firmware
https://wiki.seeedstudio.com/BeagleBone_Green/
Debricking process:
https://www.centroidcnc.com/centroid_di ... icker.html
Once you have done that, you will have to email a FRESH report to diysales@centroidcnc.com so they can update and send you a new license
tuffduck
Post by tuffduck »
Thanks Marty
seven7thirty30
CNC Control System Serial Number: 3447
Post by seven7thirty30 »
I was getting errors in my logs with the MPU requesting resends. I tried everything that I found on this forum. I solved the issue by using the USB to Ethernet adapter that came with my laptop. The problem went away and has not come back.
Dave_C
Post by Dave_C »
seven7thirty30 wrote: Thu Jun 10, 2021 2:08 pm I was getting errors in my logs with the MPU requesting resends. I tried everything that I found on this forum. I solved the issue by using the USB to Ethernet adapter that came with my laptop. The problem went away and has not come back.
This is the first mention, I think, that you are using a laptop to run Acorn. Laptops can and do bring issues to CNC that dedicated PC's don't have.
Will a Laptop run Acorn, yes, but you may be fine for a while and then you have unexpected issues that you did not have before. So why is this?
Actually you'll have to read the post on PC's verses Laptops to see why. For one, Laptops, by default, turn off certain ports to save power at certain times. The ethernet port is one of them. USB ports can shut down unexpectedly as well. There is a way to make them not turn off if you know how.
Dave C.
tuffduck
Post by tuffduck »
I am using a PC.
seven7thirty30
I guess I should have been more specific. I don't use a laptop. I just used the adapter that came with it to resolve the issue I was having on my PC.
tuffduck
Post by tuffduck »
Thanks, that helps. I will give it a try.
tuffduck
Post by tuffduck »
Still waiting for the Beagle Bone to arrive. I ran one program twice today. The first ran fine. The second was nothing but errors. Nothing had been changed. Confused as to what is happening. What other things could be going wrong?
report_0479B7E7BDC2-0205202948_2021-06-23_15-49-50.zip
(1.91 MiB) Downloaded 94 times
