Page 2 of 2
Re: Cutting Undersized
Posted: Wed Dec 25, 2019 2:19 pm
by cbb1962
I was working in my barn and found the part.
Posted: Thu Dec 26, 2019 12:47 pm
by Mkelcy
I worked around my issue (called for "oversize" holes in VCarve), but still have no idea what caused the error.
Posted: Thu Dec 26, 2019 1:23 pm
by Gary Campbell
Have you cut a slow feedrate shallow slot and measured the width that the bit actually cuts in your material? You may be surprised, some solid carbide bits are undersized a bit.
If you cut the holes once climb and then again conventional do the hole sizes change?
Posted: Thu Dec 26, 2019 10:46 pm
by Mkelcy
Gary - I'll try your suggested tests and report back.
Posted: Mon Sep 21, 2020 1:11 am
by Mkelcy
Follow-up. I've been told by the internet that my problem is an issue in the VCarve pocket toolpath (and not the hardware) and was advised to use a profile toolpath. I did and it cut the exact size hole I wanted.
Posted: Mon Sep 21, 2020 10:47 am
Mkelcy wrote: Mon Sep 21, 2020 1:11 am Follow-up. I've been told by the internet that my problem is an issue in the VCarve pocket toolpath (and not the hardware) and was advised to use a profile toolpath. I did and it cut the exact size hole I wanted.
Wow, almost a year...thanks for the follow up!
