Definitely throw me for a curve ball. I just setup by B axis rotary to turn perfect on previous version. Updated yesterday and was scratching my head. Now I have to do some configuring because my Max Rate only accepts 83 vs my 18000 mm/min as previous.cnckeith wrote: ↑Wed Mar 05, 2025 4:13 pm did we just throw you a curve ball by changing the unit that the wizard wants for rotary axes?
when in MM now the wizard wants degrees per turn. how many degrees does the rotary axis move then the axis motor is turned one revolution?
i know this will toss a curve ball to anyone upgrading as now they will have to a bit of math to convert their old number
CNC12 v5.30 Mill, Lathe, Router and Plasma has been released. 3-7-25
- CNC Control System Serial Number: E062347948F9-0324225805
Re: CNC12 v5.28 Mill, Lathe, Router and Plasma has been released. 3-3-25
Blue Elephant 1318-4th axis Rotary, 6hp Spindle with Richauto B58 DSP controller converted to Centroid Acorn, Shopbot Desktop 2418 with 1.25hp HSD Spindle
Epilog Helix 50 watt C02 laser 18"x 24" work area
Graphtec FC8000-30" Vinyl cutter/Plotter
Software: Vectric Aspire 12.0v; Rhinoceros 8 with RhinoCAM 2018; Deskproto 8.0v; Autodesk Artcam Premium 2018; CorelDraw 2020; FlexiSign Pro 10.5v
In the last beta version I could change it in the Jog menu, like the other values.
yeah, sorry it had to be done! previously the rotary units were different from inches (rev/deg) to metric (deg/rev). so the change is to make the rotary overall turns ratio units the same for both inches and mm as it has nothing to do with inches or metric. so short term confusion for users that are trying to install a new version of CNC12 with old version overall turns ratio numbers to get to long term one unit for all going forward.Boatwrights Workshop wrote: ↑Thu Mar 06, 2025 8:11 amDefinitely throw me for a curve ball. I just setup by B axis rotary to turn perfect on previous version. Updated yesterday and was scratching my head. Now I have to do some configuring because my Max Rate only accepts 83 vs my 18000 mm/min as previous.cnckeith wrote: ↑Wed Mar 05, 2025 4:13 pm did we just throw you a curve ball by changing the unit that the wizard wants for rotary axes?
1 user liked this post
- Hickory CNC Controller: Yes
Uwe,suntravel wrote: ↑Thu Mar 06, 2025 8:43 amIn the last beta version I could change it in the Jog menu, like the other values.
Those cells were previously for display only and made to reflect the values stored in P571-578. They have since been updated to be modifiable. Apologies for any confusion.
In summary, the max diff values in the Scale Settings menu are modifiable and should update P571-578 with whatever value was set in the Scale Settings menu, and vice versa. I restored your report, but was unable to reproduce the behavior you described. When I changed the values from the Scale Settings menu, P571-578 were updated as expected. Could you tell me a bit more about the issues you're experiencing?
Thank you,
Michael
Re: CNC12 v5.30 Mill, Lathe, Router and Plasma has been released. 3-7-25
v5.30 has been released.
a.) Fixed a Wizard bug introduced into the Wizard Axis menu Overall Turns ratio max rate calculation warning for Rotary axis
b.) Fixed G540 “Legacy mode” support for Acorn. G540 Legacy mode = running Acorn inputs and outputs through the G540.
c.) Fixed Smoothing Function key typo for the F key label introduced in v5.28 when updating the text in CNC12 for clarity.
I have installed it on my machines and everything is working fine now.
Thank you for the fast fix.
thanks for reporting back and your help with testing!
now onto v5.40.0! this next release will have new versioning scheme x.xx.x so we can make updates like v5.40.1, v5.40.2, v5.40.3 etc..if necessary.
New versioning scheme like this?
5 users liked this post
5.40.1
5. = main version
.40 = new features for a main version, think of it as a new chapter of the main version.
.1 = bug fixes for a chapter with no new features added
I have to say Keith that you are doing a really bad job on all these updates and bug fixes being handled so quickly. Not good man. Because you do this and only your company does this I live a very frustrated life with all the other software that I use. They just don't do it in any way near to what you do. So I am frustrated with 50 other companies because I know it can be done but they just don't do it. Piss's me off. Before you I just accepted it as that is how it must be but now I know different so I am frustrated.
