Delta ASDA-B2 ACORN WIRING INFORMATION
Re: Delta ASDA-B2 ACORN WIRING INFORMATION
New picture
new pic.
Question to cnckeith
enter acorn delta parameters
confirm correct parameters
what is that and where to find it ?
Hi
about acorn setup number I find those setup on the web somewhere , is that you mean by acorn setup number ?
I reset the drive to factory , I input the number , I plug the step and dir into the db25 at 2 and 3 . I enable the db25 in cnc12.
Good news no axe are moving at all . the axe that I was working on is the X axe . the power is on cnc12 is connecte to acorn noting move , but the X axe is free no power to it even if the drive is on .
More info Please .
More info Please .
I think you would benefit from this:
https://cnc4pc.com/c86-connector-acorn-cnc.html
https://cnc4pc.com/c34de-for-delta-b2-driver.html
Arturo Duncan
https:/cnc4pc.com
Arturo Duncan
https:/cnc4pc.com
Arturo Duncan
https://cnc4pc.com
https://cnc4pc.com
Acorn to Delta parameters.
reset to factory settings! and then follow this TB
https://www.centroidcnc.com/dealersuppo ... ds/303.pdf
follow this wiring diagram for AcornSix
https://centroidcnc.com/dealersupport/s ... 154.r1.pdf
and for Acorn
https://centroidcnc.com/dealersupport/s ... 102.r1.pdf
and for Acorn
Nothing work . I did all and nothing .
- Hickory CNC Controller: Yes
Have you tried running the delta drive through their software? As in simple jogging etc. If that eorks you know at least the drive is working. Asdasoft also allows you to see any errors etc.
Additionally it is very hard to remotly diagnose something without being provided with a step by step log of wat works and what does not work.
Keith
The delta drive is to factory reset.
Load the number (gain button section )
start cnc12.
try to move the axe , it move very fast ,reverse the movement and the drive stop .
drive show Al009
start cnc12.
drive show Al009
