I/O presets
terrymcc
CNC Control System Serial Number: waiting on delivery
I/O presets
Post by terrymcc »
I am starting the conversion of a machine to Acorn/CNC12. I am using an Ethernet 1616 board. In the Wizard, I can build the inputs and outputs. The system sees the 1616 and jumper testing shows it is working. I want to save this preset and load a simpler preset to start doing the basic bench test now that I have drives. When I select the Advanced I/O Configuration button to create this custom preset, it does not show that there is an expansion board and generates an error when I try to create or export the presets.
Any idea what I’m doing wrong?
Chaz
Re: I/O presets
Post by Chaz »
Struggling a bit with the question. Are you trying to set outputs so that you can use them later in some custom code?
terrymcc
Re: I/O presets
Post by terrymcc »
No, I wanted to save my final presets so that I can load the basic bench test presets to test the drives. Then later, I can load the presets with all the needed I/O
Chaz
Re: I/O presets
Post by Chaz »
Save a report, then restore a report. That should work as it does all the mapping etc.
Re: I/O presets
what version of CNC12 are you using? please post a fresh report.zip.
and yes, its super easy to save/restore reports for different configurations.
or alternatively, simply copy/rename the entire cncm directory to quickly switch between them.
Allin1Chris
PLC Expert
Re: I/O presets
Post by Allin1Chris »
terrymcc wrote: Sun Apr 20, 2025 2:23 pm When I select the Advanced I/O Configuration button to create this custom preset, it does not show that there is an expansion board and generates an error when I try to create or export the presets.
Hello, can you be more specific on the error that the wizard gives you? Maybe a snip or screen capture of the error, be very useful.
In addition, The expansion Board I/O may not appear in the Preset Box, however it will both save and load the Expansion Board I/O regardless.
Centroid PLC Tutorial Videos
