Torno, Mastercam y post processor
hardy9000
Post by hardy9000 »
Hola
He modificado un torno manual a cnc con Centroid, pero cuando realizo el dibujo del desbaste de un eje en mastercam y a la hora de correr el programas el eje x rebaja más de la cuenta, pero si mando manual a X a 4 pulgadas este está exacta.
Mi duda es que no se cual de los post procesador que trae Mastercan funcionan bien con Centroid o si es problemas de algún ajuste que falta.
I have modified a manual cnc lathe with Centroid, but when I make the drawing of the roughing of an axis in mastercam and when running the programs the x axis reduces more than necessary, but if I manually control X at 4 inches it is exact .
My question is that I don't know which of the post processors that Mastercan comes with work well with Centroid or if it is a problem with some missing setting.
centroid467
Re: Torno, Mastercam y post processor
Post by centroid467 »
Please post a current report from the Centroid control and a sample program that shows this behavior. How much deeper than expected is the X axis cutting?
did you configure the machine tool and verify motion, commanded vs actual before running a g code program?
hardy9000
Post by hardy9000 »
si se verifico el movimeinto real y el de ordenado, mas adelanrte le dare mas informacion de cuanto es el error con mas detalles y programa de muestra.
