Greetings,
I've almost finished upgrading a Aciera mill from a DCIO3 to an AllinOne controller.
Can I use the wired MPG from the DCIO3 with the AllinOne system?
It is an EHDW-BA5S-IM.
If so, is there a pinout for the conversion?
Can I use a Pendant from a DCIO3 with an AllinOne
- CNC Control System Serial Number: 1218120647
Re: Can I use a Pendant from a DCIO3 with an AllinOne
I'd take a look at page 12 of the ALLIN1DC individual circuit set S14996 (https://www.centroidcnc.com/dealersuppo ... df#page=12) and the CNC10 MPG cable schematic S14619 (https://www.centroidcnc.com/dealersuppo ... 619.r1.pdf)
No.
The old MPG handwheel pendant has a single-ended encoder (one wire per channel).
The Allin1DC requires an MPG handwheel with a differential encoder (two wires per channel).
1 user liked this post
Thanks again CNCSNW!
