Cheap CNCPC that meets requirements: Lenovo Think Center M93P and HP G3, Beelink
Sword
Re: Cheap CNCPC that meets requirements: Lenovo Think Center M92P for Acorn <updated model M93P>
Post by Sword »
dustboy wrote: Tue Apr 11, 2023 8:26 pm Ordered a "renewed" M93P on Amazon, it is NFG, no boot, seems like disk issue (the blue screen of death told me so). I'm afraid we are scraping the bottom of the refurbishing barrel on this model. I'm one of those dumb "Apple" guys who doesn't understand the "Quad-encabulator Raizen i97 6900T 1.21 jigawatt" lingo, so I'm leaning on you guys for a recommendation. What's next?
Either return it to Amazon, or you could try creating a bootable USB drive to attempt to diagnose it, or reinstall Windows with it. You'd probably need to enter the BIOS to make sure it is set to boot from USB. It did come with a hard drive/SSD? Many are sold without, and you need to make sure.
Scott
dustboy
CNC Control System Serial Number: Acorn-905
Post by dustboy »
I made a USB recovery drive on my router PC and ran a clean install twice, unsuccessful. Something is wrong with the hardware, so back it goes to Scamazon. One of the USB ports was bad too, so that is reason enough.
I ordered a refurb NUC i5-7260U for a bit more money on fleaBay, based on Centroid's recommendation. Looks like it benches at 1,993 which is almost double what is required for a lathe.
My build: Making a CNC P-to-P boring machine less, uh, boring: https://www.cnczone.com/forums/diy-cnc- ... -axis.html
Re: Cheap CNCPC that meets requirements: Lenovo Think Center M93P and HP G3
here is another.
HP Micro Desktop Computer 800 G3 Elitedesk Mini Business PC
https://amzn.to/3NamUna
glbreil
Post by glbreil »
Hello Everyone one, since it looks like the NUC numbers and availability change everyday, if you were shopping for a NUC type today what would you buy?
Thanks Gary
Houseman303
CNC Control System Serial Number: A901313
Post by Houseman303 »
lenovo ThinkPad W540 Works great for CNC control and CAD/CAM at the same time
The Intel NUC is way overpriced and you are paying for the name. There are dozens of 1L pc’s on the market that are a 1/2 to 1/3 the cost and just as good or better. This topic lists many of them if you read through it. Just be sure to get one that meets the Centroid minimum pc specs. Lenovo, HP, Dell, Beelink are just a few.
this is the one we recommend if you are going to buy new and diy it,https://amzn.to/49ey9D7
be sure to run the free Centroid PC Tuner on any PC that is destined for CNC duty!!
jhnmdahl
CNC Control System Serial Number: C182115
Re: Cheap CNCPC that meets requirements: Lenovo Think Center M93P and HP G3, Beelink
Post by jhnmdahl »
For the Beelink Equ12, the single core passmark for the 1220p ($259) is 3380 and multithread is 14520, while the 12450h ($309) single core passmark is 3352 and multi core is 16728. I bought the cheaper 1220p with the higher single core performance, and have no complaints, and appreciate that I have some "headroom" should it be needed in the future.
MartinC
Post by MartinC »
Just purchased a Beelink N100 mini-PC, a S12 pro mini https://www.amazon.de/dp/B08DFL2L1F?ref ... asin_title
I don't have an Acorn yet so I can't say for certain if it will work. Single core benchmark should be plenty. PC tuner says it should be OK (except for the missing Acorn board of course).
Is there a mode to run CNC12 without controller board connected?
Cute little machine. Jaw-dropping value for money I'd say, €170 for the PC including 16G RAM, 500G SSD and Windows 11 pro. They don't advertise the Windows license, but I reinstalled Windows 11 and the installer did not even ask for a license, so it found something in the BIOS maybe? Worst case I'll need to purchase a license later.
Installation was not without problems, would not boot from USB stick (Win 11 pro was preinstalled, but I wanted to get rid of that in case crap- or malware was installed). Ran installer from USB stick after Windows had booted (which worked fine and I told it to do a clean install). Boot still shows Beelink icon so it was not a total wipe (maybe the logo is stored in the BIOS). Finding drivers for the chipset was also a bit painful, although most of the peripherals are supported natively by W11. This one will replace my HTPC, I'll get a second one for Acorn once I get around to it.
Compared to this unit Asus (formerly Intel) NUCs are totally (2-3x) overpriced.
You can use the offline version without a connected board.
