issue with plasma intercon V0.91 BETA
Moderators: cnckeith, Joey
Cam6.7Cummins
Plasma CNC Controller: Yes
CNC Control System Serial Number: (302837901215215447)
Post by Cam6.7Cummins »
Hey as far as I remember it was working before I did the plasma V5.10 update. Now as you can see by the pictures of the intercon vs the posted its adding some shapes, I believe it only does it to rectangles.
Joey
Plasma/Laser Lead
Re: issue with plasma intercon V0.91 BETA
Post by Joey »
Hello Cam Thanks for Posting
Can you Post the Plasma Intercon Job file? This will be a .icp file
You can select File-Save as to save the .icp Job file.
Can you also Post the DXF if this was an imported DXF also.
This will help us determine what the issue is.
Cam6.7Cummins
I have cnc file attached, if I try an icp it says "Invalid file extension: Series 60 plate.icp"
Series 60 plate.cnc
(1.61 KiB) Downloaded 13 times
Joey
Plasma/Laser Lead
Post by Joey »
I see that, to get around the extension issue just Rename the .icp file and replace the .icp with .cnc
Joey
Plasma/Laser Lead
Post by Joey »
Changes were made to the Forum, Plasma Intercon .icp files are now accepted
Cam6.7Cummins
Hey, no DXF files used. Was drawn with intercon.
Cam6.7Cummins
got an ICP here, thanks for your time!
Series 60 plate.icp
(3.62 KiB) Downloaded 10 times
Cam6.7Cummins
Okay I've been playing around with it and the shapes appear when you add a lead in/out one for each, pictures attached.
Cam6.7Cummins
Second issue I've come across is the first hole in a couple will be smaller than entered. I've attached screen shot and ICP
The issue can be fixed by deleting the first and entering it later in the events.
testing hole pattern 1.3.icp
(2.34 KiB) Downloaded 8 times
ASPeters
Post by ASPeters »
Hello,
Your first issue was caused by an error in the cutter comp portion of the post process.
I wasn't able to replicate your second issue.
Here's a new build of Plasma Intercon to correct that first issue:
viewtopic.php?f=67&t=10491
