CENTROID Hickory Install Manual?
- CNC Control System Serial Number: 7804732D0434-050819202, 0008DC111213-0120230049
update cnckeith writes " Hickory DIY installation Manual is here"
Hello
when will be avaiable CENTROID Hickory Install Manual?
best
Andrzej
Hello
best
Andrzej
Re: CENTROID Hickory Install Manual?
Hickory DIY install manual.
search 'hickory' for drive specific setup instructions.
https://www.centroidcnc.com/centroid_di ... browse.php
examples
https://www.centroidcnc.com/dealersuppo ... ds/322.pdf
https://www.centroidcnc.com/dealersuppo ... ds/317.pdf
But be sure to check back as we continue to add to and improve the documentation.
examples
for a limited time we are offering early adopter Hickory customers Free one on one tech support via Teamviewer.
contact support@centroidcnc.com to arrange a time for the TV session. put in subject line of email "Hickory Tech Support"
State of inovance testing
- runs on bench but has more following error than yaskawa and estun. we are reaching out to the inovance techs for advice.
- getting ready to mount the inovance to a machine for realistic testing
Leadshine EL7 and EL8 setup instructions added to the TB page. https://www.centroidcnc.com/centroid_di ... browse.php
EL7 https://www.centroidcnc.com/dealersuppo ... ds/323.pdf
EL8 https://www.centroidcnc.com/dealersuppo ... ds/324.pdf
All Hickory schematics are here.
type in "hickory" in the search bar
Any plan for Delta Asda3 On Hickory?
we tested a 3 year old delta and it doesn't work.
hoping to get our hands on an updated model. delta is hard to buy in the USA.
if you have one send it to us and we will test and if it works create instructions and a schematics on how to configure it with hickory.
hickory ethercat haas mini mill 2001 .
spindle motor curently use ac 320 volt using a haas servo amplifier
i know i have to replace the haas drive this something motor 800 rpm looks like 3 phase motor 10 hp there no tags
question what would be my best choice make model on VFD to control the spindle motor it need encoder input for spindle orientation
how does hickory handle that
the other how does hickory handle tool changer wiring
haas using dc motors with limit switches it turns and triggers 1 switch it not servo driven
in and out the same 2 limit switches
first Draft Overall Installation Manual is attached.
comments and suggestions are welcome.
Thanks Keith for the manual. I have been reading through it and have a couple of questions. It has been quite some time since I did my initial bench testing and there are several steps added here in the manual that weren’t in the original sheets, such as the communication stress test and spindle bench test.
I have everything mounted in the machine at this point and I am very close to start up. I intend to do some back tracking and perform those additional tests, which I assume is a good idea.
The main question is about the set up of the LeadShine EL7 motors and drives. There is no mention of the tuning of the motors using the factory software in the manual. I assume that should be completed before ever hooking the drives to Hickory or should that step fall somewhere in the tuning and set up of the CNC12/Hickory?
Thanks Gary
Thanks Gary
Hello Gary,glbreil wrote: ↑Tue Mar 26, 2024 9:26 am Thanks Keith for the manual. I have been reading through it and have a couple of questions. It has been quite some time since I did my initial bench testing and there are several steps added here in the manual that weren’t in the original sheets, such as the communication stress test and spindle bench test.
Thanks Gary
I am a little out of the loop on the Hickory documentation and plans for it going forwards but the steps for tuning in the EL7 tech bulletin should still apply. You can find that document here: https://www.centroidcnc.com/dealersuppo ... ds/323.pdf
