Default File Location
RJS100
Post by RJS100 »
In CNC12, when you hit F2 to load a CNC file, the default file location is: C\CNCM\NCFILES. Is there a way to change this default file location?
I looked in the manual but was not able to find it.
Richard
Re: Default File Location
pathm.ini in the main folder.
Default is:
intercon_path=C:\intercon\
icn_post_path=C:\cncm\ncfiles\
digitize_path=C:\cncm\ncfiles\
cad_path=C:\cncm\ncfiles\
default_load_path=c:\cncm\ncfiles\
RJS100
Post by RJS100 »
Many Thanks!
Covered in section 15.1 in the user manual.
Sword
Post by Sword »
Another good option, parameter 004 set to 25.
Scott
Sword wrote: Mon Nov 27, 2023 9:23 pm Another good option, parameter 004 set to 25.
This is your best option.
EastMemphis
CNC Control System Serial Number: 0035FF98BF3B-0325225816
Post by EastMemphis »
Is it standard procedure to just keep emptying the load path of old jobs? I've taken to calling everything the same thing to keep that directory from being flooded with junk files. I transport gcode to the machine using an SD card.
Is there a better way?
Set parameter 4 to 2, this will cache the files to the C drive for cutting but not copy it to the ncfiles folder. It will be deleted when you load the next file.
Do you really use a SD card or is it a USB drive? I've never heard of anyone using a SC card.
dpascucci_support
Post by dpascucci_support »
It should be noted that parameter 4 is bit-mapped, so if you want it to open windows file dialogue, remember the last opened location, and turn on file caching, you would set the p4=26.
Domenic
dpascucci_support wrote: Tue Nov 28, 2023 1:24 pm It should be noted that parameter 4 is bit-mapped, so if you want it to open windows file dialogue, remember the last opened location, and turn on file caching, you would set the p4=26.
Yes, sorry it is a bit mapped parameter.
